Need advice on repair of lower ball joint
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco Egghead, Mar 4, 2025.
  1. Mar 4, 2025 at 1:44 PM
    Taco Egghead
    Taco Egghead [OP] Well-Known Member
    Hey all, my truck has been driving out of alignment lately with a vibrating steering wheel and wearing on the inside of my front tires. I went in to my appointment and explained my issue and the mechanic noticed that my front passenger side lower ball joint is likely one of the main culprits to blame for this. He gave me a quote which included using their part (Napa or precision) which they will warranty but the thing is is that I'm not going to need the warranty since I'll be moving out of the state soon. Can I just buy a cheaper MOOG part for $40 and save myself $60 in parts or is the quality difference significant enough to where I should go with their part? Thanks.
  2. Mar 4, 2025 at 2:06 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I am a big believer in OEM parts on a stock truck.
    You get what you pay for.
  3. Mar 4, 2025 at 4:22 PM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    pretty sure the lower ball joint is considered a no serviceable part, so toyota recommends replacing the whole LCA. you can find aftermarket lower ball joints, and there might be a part number that you can find for a oem toyota lower ball joint. i think most people would recommend oem on something like a ball joint
  4. Mar 4, 2025 at 4:52 PM
    Taco Egghead
    Welp I asked the mechanic if we should just replace the entire LCA and he said no need to and it would cost me more, so indeed it is possible to just replace the lower ball joint by itself. Apparently people do it with speciality tools from your common auto parts stores according to what I've read online.
  5. Mar 4, 2025 at 4:58 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I’m not trying to spend your money but it would be best to buy a OEM LCA with ball joint already installed.
  6. Mar 4, 2025 at 5:00 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    The ball joint would have to have alot of play to cause any sort of tire wear. And def would not cause a vibration. Not going to say your mechanic sucks but that diagnoses is not true. I'm sure the boot is leaking and he just wants to replace it.
  7. Mar 4, 2025 at 5:08 PM
    808stateofmind
    Kona
    you can definitely use a ball joint press and press the ball joint out, but because the lca isnt designed to service the ball joint it could be potentially unsafe, although im sure it would be fine. for aftermarket ball joints, I dont know of any ball joints that are gonna be even close to the quality of oem. I thought moog used to be good quality, but ive heard from a lot of people that moog isnt the same as it used to be
  8. Mar 4, 2025 at 5:31 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Napa doesn't manufacture its own ball joints, so it'll be an existing brand (Moog, 555, Mevotech, TRW, etc.) in Napa packaging. It costs more because Napa provides an easier warranty and Napa makes a profit.
    The $2000 off-road performance LCAs from Dirt King, BTF, etc. use Moog ball joints. So Moog is good enough. TRW (owned by ZF) is also good enough.
  9. Mar 4, 2025 at 6:41 PM
    akimmel
    akimmel Well-Known Member
    Alex
    2019 TRD OR DCSB 6MT
    Do you have a small floor jack and a prybar or similar? you can check the ball joint yourself fairly easily with those alone. Lift on the lower control arm, and pry the tire up and down listening and feeling for play. You can reach around the tire to where the knuckle meets the LCA and get a feel for if there's any slop at all. You can buy just the OEM balljoint on ebay, as a Hilux lower balljoint, but you might have a hard time convincing someone else to put it in for you. I did one this way myself and its been on there almost a year without issue.
    Taco Egghead[OP] likes this.
  10. Mar 4, 2025 at 6:58 PM
    Taco Egghead
    If the boot is leaking would'nt I see it?
  11. Mar 4, 2025 at 7:00 PM
    Taco Egghead
    The mechanic is the one that recommended this repair when I went to get an alignment done.
  12. Mar 4, 2025 at 7:02 PM
    MGMDesertTaco
    48068-04060 right lca
    48069-04060 left lca
    If you get them on sale they run about $250 each.
  13. Mar 4, 2025 at 7:06 PM
    Taco Egghead
    I'm ballin on a budget haha. The part from the mechanic will be $106 for the ball joint. I can afford that better than a $250 LCA right now...
  14. Mar 4, 2025 at 7:07 PM
    MGMDesertTaco
    Yeah, but what are they charging for labor? I just bought new oem lca's for that reason. Plus you get new bushings.
  15. Mar 4, 2025 at 7:09 PM
    Taco Egghead
    $142.99 for the labor. Plus $15 for shop supplies and $26 for sales tax. Is all of that too much? I don't have the money, space, time, or tools to mess with an LCA I've never installed before.
  16. Mar 4, 2025 at 7:10 PM
    akimmel
    Alex
    https://www.ebay.com/itm/154012666304. This is the listing I purchased from, the parts gave me no reason to believe they were anything other than brand new OEM. The price is for 2 of them.
  17. Mar 4, 2025 at 7:11 PM
    MGMDesertTaco
    That's cheap for the work involved. You'll need an alignment after too.
  18. Mar 4, 2025 at 7:16 PM
    Taco Egghead
    You're the 2nd person that's told me it's a decent price. Alignment will be 69.99 so after everything will be roughly $360. If that sounds good to you guys I'll go through with or I can also order my own, cheaper non OEM, part online which will not be under warranty but I don't need that since I won't be much longer in this state.
    MGMDesertTaco[QUOTED] likes this.
  19. Mar 4, 2025 at 7:22 PM
    MGMDesertTaco
    I would stick with oem for best fitment. Ebay has several sets for $70.
    43330-09510
  20. Mar 4, 2025 at 7:26 PM
    Taco Egghead
    I looked that serial up in the Ebay search bar and there are a lot of pairs of ball joints claiming to be genuine and OEM that range in price from $65 to $145 hahaha. This whole process is giving me a few extra little gray hairs.
    RIX TUX likes this.
