Need advice on sealing transmission pan
Discussion in '1st Gen. Tacomas (1995-2004)' started by JustADriver, Nov 15, 2024.
  1. Nov 27, 2024 at 5:10 PM
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    I've done mine twice. First time FIPG. Second time cork gasket. I was worried about the cork, but it hasn't been a problem. Probably been 6 months and no leaks whatsoever.
  2. Nov 27, 2024 at 6:08 PM
    OLDHMECH61
    OLDHMECH61 Well-Known Member
    Andy
    Odessa FL
    99 Prerunner Std cab green
    1UZ swap, trutrac diff, tundra brakes, 3 lift, FJ rims
    Its been a couple of years IIRC i put a 10 mm socket in a vice put the bolt in head first then smacked the tail with a hammer and the socket will push the washer off, you wont hurt the threads of the bolt its piloted for the first 1/16
    good luck
    R/
  3. Nov 27, 2024 at 6:11 PM
    JustADriver
    JustADriver [OP] Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    Problem identified. The pan flange was bent in at several bolt holes. Removing one bolt at a time and bending the spots back with pliers actually slowed the leak. I'll probably take the pan off sometime soon and get it perfectly flat. I expect that will do it.
  4. Nov 27, 2024 at 7:34 PM
    Kristi with a K
    Kristi with a K Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    Do you recall what brand sealant? I've used the permatex copper spray. Not sure if it's ok with ATF.
  5. Nov 27, 2024 at 7:51 PM
    PaulyFromLA
    PaulyFromLA Well-Known Member
    Pauly
    1st gen tacomas
    Ones a camper, ones oem, ones a flatbed
    i use the toyota gasket maker stuff, make sure to grind off the old stuff/debris off, tighten to spec torque in a star, let it sit for 24 hours, then add the atf
    Kristi with a K likes this.
  6. Nov 27, 2024 at 9:50 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Permatex red is typically what I use. No issues ever
  7. Nov 29, 2024 at 2:29 PM
    Kristi with a K
    Western MA
    So I decided to check the pan bolts. Yeah. I know. Maybe, just maybe, that should have been done already….
    Anyway, I did “drop” the transmission in January, did valve body work, etc. All’s that to say that it hasn’t been that long since the last pan drop.
    When I checked the bolts, there were some pretty loose ones. Now if they were all say, the rear ones, I’d admit that maybe I missed them? Doesn’t attest to my cross tightening due diligence, but ok. It was one heck of a long job I did. Point is, the loose ones were random. One middle left, another front right, etc. & by loose I mean a couple I had to give 4/5 twists of the ratchet. A couple others, maybe 3 twists. Many were fully torqued.
    Is it possible the bolts could have loosened up that much? I’ve never had a bolt break or replaced any. In other words, no mods required that would compromise the bolt holes.
  8. Nov 29, 2024 at 2:38 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I've used Permatex and Black Magic Form-A-Gasket products.
    Besides a clean dry prep.,
    Some of those gasket makers work best if you finger tighten them 1st and wait 10min, until it starts to cure, before torquing it down.
  9. Dec 5, 2024 at 5:01 PM
    JustADriver
    Update - Aside from the bent flanges, the pan bolt holes were all terribly dimpled. I'm surprised it sealed as well as it did. I had noticed that before but thought it was by design. Obviously a little thought would tell me the mating surface needs to be uniform!
    Repaired, cleaned, installed pan stiffener, farpak gasket, and spring washers on bolts. Over the last day I keep having to retighten the bolts to stop a leak. Not more torque, just a smidgen more to regain the same torque for some reason. Seems good now but we'll see. The pan stiffener is great, prevents gasket or pan damage. Bastards should have built it that way. The farpak/fiber gasket is hard thin material and probably seals great right away if your pan was never damaged.
    So pretty much all set. If need be, I will try a cork gasket (thicker and more spongy) to compensate for the remaining imperfections, or RTV as a last resort which would definitely work the best (it almost worked with my pan bent to trash).
  10. Dec 6, 2024 at 9:59 AM
    Kristi with a K
    Western MA
    Appreciate the follow through (update). It’s frustrating when you read a thread cuz you’ve got the same issue, only to get to the end & …. Crickets….
