Need Advice on shocks/coilovers, rear springs and this POS lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OldBluTRD, Mar 27, 2015.
  1. Mar 27, 2015 at 11:06 AM
    OldBluTRD
    OldBluTRD [OP] Active Member
    Clay
    Golden, CO
    05 SpdyBlu TRD-OffRoad aclb
    Ome 2887s Bilstein 5100s 285/75/16 BFG AT2 Stealth Custom Series Ray10 ARE custom cut shell from an S-10 Half ass overland rig in the making.
    2005 TRD Off Road SR5 Access Cab
    Currently set up-
    2.5 Daystar spacer lift in front
    on stock OEM shocks and coils
    2" blocks in rear w/ stock OEM shocks
    1.25 Spydertrax spacers
    285/75/16 Goodyear Duratracs on stock TRD wheels
    My shocks are shot and feel pretty much worthless at this point. I spend a decent amount of time off-road, but try to keep the temptations to really go wheeling for the Jeep ( since its already beat to hell). Soon, I plan to go back to 265/75/16 but want to stay slightly lifted. Total Chaos UAC's are also coming soon.
    I want to get rid of the Daystar lift and find a smoother/softer ride with either Bilstein 5100's, OME or maybe Toytec. Here is where I get overwhelmed. The combo of Billys and new coils or is coilover a better option? Then, should I go with AAL or spend the extra for new packs? Is some combo of this going to give me apx 3" lift and give a smoother ride? AND THEN do I NEED a diff drop?
    Ive read and read on TW and clearly there are tons of options. Price is a mild factor. Trying to stay under $2000 but I'm open to quality options. Any advice is appreciated! Thanks
  2. Mar 27, 2015 at 11:43 AM
    Pigpen
    Dan
    Northwest Montana
    Go full OME with no regrets. Do it once, do it right.
  3. Mar 27, 2015 at 12:03 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    ^^^^^what he said, do it right. At the age of a 2005, def get new rear leaf packs with whatever option you do. OME would be a good choice for you, a great lift that doesn't cost a fortune. I opted for Toytec coilovers personally on my lift. When I replace my suspension, I'm going with Fox or Icon next time. Spacers and blocks just suck.
  4. Mar 27, 2015 at 7:11 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Welcome OP! :wave:
    First and foremost no diff drop. Based on your post your looking at a max 3" lift which is good. As you've probably read, diff drop gets bad reviews from most here.
    I'd go OME/Toytech/Boss as others have said. You can get into a very decent lift with AAL for around $1,200 max.
    If $ isn't an issue and you want to wheel the Yota instead of the Heep ;), ICON, King or Fox setups will do you really well. If you go this route you could either go the AAL route, or just swap the leaf pack with Dakar, Deaver, Wheeler, etc. But you'll probably have to shim the rear leafs if you swap the factory leafs with one of these aftermarket options and maybe even throw in a driveshaft spacer for vibration correction. Most will tell you though unless you're hauling or towing, Dakar, et al might be overkill. I went full Dakar because I occasionally haul, wheel quite a bit, and might throw a topper and/or RTT on at some point (= more ass-end weigh requiring more support to avoid sagging in the rear).
    Get that spacer shit off there though, a well invested & proper suspension lift is very much worth it! :thumbsup:
  5. Mar 28, 2015 at 6:19 AM
    OldBluTRD
    Clay
    Golden, CO
    Thanks for the input! Ive been leaning towards the OME and new packs. Just needed a bit of confirmation!
    Where can I order a driveshaft spacer? Any specific recommendations? And with OME, should I use factory coils?
  6. Mar 28, 2015 at 6:23 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Any vendor on here will likely have the CB drop. Like mentioned earlier, with an 05, all the springs are likely shot. New coils would be an upgrade over the stock ones.
