Need advice on suspension lift
Discussion in 'Suspension' started by toyohtadude, May 24, 2014.
  1. May 24, 2014 at 10:46 AM
    toyohtadude
    toyohtadude [OP] Well-Known Member
    Eric
    Austin, TX
    2017 4x4 Tundra SR5 CrewMax
    Bone stock
    '07 DC TRD Off-Road.
    Current:
    Front = Hell Bent Steel 2.5" spacers
    Rear = TSB leaf pack with Toytec TSB AAL kit
    Four BORA 1.25" wheel spacers
    Proposed:
    Remove Hell Bent and replace with OME Kit (885 coils and top spacers) http://toyteclifts.3dcartstores.com/OME-Tacoma-Suspension-lift-kit_p_231.html but either sell the OME AAL or work a deal with Toytec to get this kit without the AAL included.
    http://www.headstrongoffroad.com/light-racing-spc-ucas-for-05-toyota-tacoma.html Light Racing UCA's to insure proper travel and alignment.
    Now the questions:
    • Do I need the swaybar relocation kit?
    • Axel degree shims?
    • Longer brake lines front and/or rear?
    • Carrier bearing drop?
    Thanks in advance for any advice. This site has been extremely helpful in every way. I appreciate all the input you all add.
  2. May 24, 2014 at 12:38 PM
    toyohtadude
    Eric
    Austin, TX
    Bone stock
    It appears that bjmoose's stickied thread answers just about all of this as he did eventually add the LR UCA's, address the swaybar and driveline and recommended the brake lines. What has been your experience with any/all of these?
  3. May 25, 2014 at 12:55 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I have OME 887s in the front with OME Nitros, taco lean spacer in the drivers side. Dakar leaf packs in the rear with OME Nitros. Not exactly what you have, but close. I installed the carrier bearing shims and extended rear lines. I will be doing a swaybar relocate or removal soon due to the coils hitting the swaybar in the rough stuff. I also have Camburg UCA's with moog ball joints, my alignment specs are good with 3" of lift in the front. I have no vibes or issues in the approximately 1200 miles since the install.
  4. May 26, 2014 at 8:15 AM
    toyohtadude
    Eric
    Austin, TX
    Bone stock
    Thanks RogueTRD. This is exactly the feedback I'm looking for. I've only ever leased Toyotas in the past. This is my first owned truck and first time exploring a lift. I don't want to have to revisit things after the install so getting it right the first time is key. Info like this helps a lot!
    Most of the items I question are the cheaper parts so it's nothing to add them to an order. :D I have an email out to Headstrong asking about a custom package price. I'm doing the same in a few for Toytec.
  5. May 26, 2014 at 8:19 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    How level are you?
    Are you running Armor?
    I ask because I have the exact same stuff in my shopping cart @ Wheelers right now.
    xoxo,
    -Dan
  6. May 26, 2014 at 8:24 AM
    RogueTRD
    Cade
    So. Oregon
    It sits pretty level, there are pics in my gallery. The rear is a bit higher than the front front hub to fender.
    No armor yet.
  7. May 26, 2014 at 8:44 AM
    toyohtadude
    Eric
    Austin, TX
    Bone stock
    Once the suspension is done, I intend to work on the paint. Getting rough in a few small spots... she's been used as a truck so it was expected. When these Michelins wear out, I will get some new wheels and more aggressive tires. Those Cooper ST Maxx look cool! Considering moving from 16" to 18" wheels too.
  8. May 26, 2014 at 10:51 AM
    RogueTRD
    Cade
    So. Oregon
    I can't say enough good things about the Coopers so far. My one and only complaint is that they tend to collect gravel. lol
