Need Advice on Tires Please
Discussion in 'Wheels & Tires' started by jabrackin, Jan 15, 2011.
  1. Jan 15, 2011 at 5:30 PM
    jabrackin
    jabrackin [OP] Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    I am at 45,500 miles right now and I am going to be getting new tires at the 50,000 mark. I have the Off road truck so I have the bf goodrich rugged trail tires. I have also had the TSB to add the leaf in the rear of the truck so it gave me a small rise, but i also did the billsteins in the front to level the truck out. So it has raised my truck just a tad. With me having 265/70-16 tires...... could i get a larger tire? Would it mess with my speed settings? I am thinking about michellen tires or the same set I have or the BF goodrich allterrain...... any sugguestions?
  2. Jan 15, 2011 at 5:54 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
  3. Jan 15, 2011 at 5:56 PM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    You can go with a 265-75-16 with only minimal affects on your speedometer readings. Check out the Yokohama Geolander ATS's. They're a great tire. A couple of us on here just put some on our trucks.
  4. Jan 15, 2011 at 6:07 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    You can do 265/75/16 and not really change anything. I have never heard of anyone likeing the rugged trails. I would suggest the michellin's or BFG's if you wanna do any offroading.
  5. Jan 15, 2011 at 6:11 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    You get the blackwall or the white letter tires?
  6. Jan 15, 2011 at 6:12 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    Yokohama tires look good.
  7. Jan 15, 2011 at 6:15 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    I went with the white letters out.
  8. Jan 15, 2011 at 6:22 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    did you have a lift on your truck? I had the TSB done to my rear and then I had the billsteins put on the front to raise it up some to level. I have the 265/70/16.
    It looks like on Tirerack.com that they are running 136.00 a tire.
  9. Jan 15, 2011 at 6:24 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
  10. Jan 15, 2011 at 6:30 PM
    Nick Sells
    Nick Sells Well-Known Member
    Elgin, South Carolina
    2016 TRD Off Road
    Bone Stock
    I have 265/75/16 BFG AT KO's they have the white letters but I had them installed facing in that's as big as you can without a 3" or more lift even with the raise you have they will fill up the wheel well nicely and according my GPS there really is not a noticeable difference with the speedometer.
  11. Jan 15, 2011 at 6:34 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    I am wondering if go with the 265/75/16 if I will get any rub.... My truck sits just a tad higher since the TSB to the rear and the front shock fix witht he billtein billys
  12. Jan 15, 2011 at 6:35 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    Nick did you take your mud faps off? I am wondering if I will be okay since I had the TSB done that raised the rear and i brought the front up to 1.75?
  13. Jan 15, 2011 at 6:45 PM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    x2 on the Geolander's. Nice light tire with a good A/ T design. Had em on my last rig and really loved em. Slighty larger tire will bring your speedo more in line too.
  14. Jan 15, 2011 at 7:09 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
  15. Jan 15, 2011 at 8:19 PM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
    You shouldn't rup at all with the 265/75/16. I had mine with zero problems for about 3 weeks before the billys and AAL went on. I went with black letters out.
  16. Jan 15, 2011 at 9:08 PM
    Nick Sells
    2016 TRD Off Road
    Bone Stock
    no rub whatsoever especially with the tsb and billy's your good to go and I still have my mud flaps on also.
  17. Jan 15, 2011 at 9:21 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I bought the Hankook DynaPro ATM RF10 for my truck. I had researched it quite a bit before my purchase. 1st they came in p-metric so they would not be to heavy. 2nd they won all the tests that I could find online (beating the BFGoodrich and Toyo's). 3rd they get great reviews on sites like Discount Tire Direct. 4th and very important at the time I only paid $125 per tire for them.
    I have had them for 9 months and about 7.5K and I can say that I like them very much. Smooth Ride, great traction, quiet and aggressive looking.
    Good Luck with your decision.
  18. Jan 16, 2011 at 12:30 AM
    ACE808
    ACE808 Well-Known Member
    DDS
    808 State
    TRD Off Road 4x4
    Toytec 3" lift light racing uca moto metals 17" (958) k&n intake Helix throttle body Borla exhaust Nfab step bar All-pro transfer case shield All-pro spindle gussets All-pro sway bar links All-pro E-locker guard All-pro rear differential armor All-pro U-bolt flip kit L.E.D. White/Blue Dash Gauge lighting Full alpine stereo with TV screens Clifford alarm optima red top battery Full wet okole seats auto meter gauges (oil pressure & volt meter) Ebc slotted & dimpled rotor Goodrich braided brake lines Hawks Lts brake pads Rear diff breather relocation
    Goodyear duratracs. Great tires. Can't go wrong
  19. Jan 16, 2011 at 2:05 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I have 265/75/16 BFG A/Ts, no rub at all and the tires are soo much better than the crap rugged trails that came with the truck.
  20. Jan 16, 2011 at 11:04 AM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    I live right off Lovell Rd. Close to Turkey Creek
