Need advice on ToyTec lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by bobc, Jun 1, 2018.
  1. Jun 1, 2018 at 6:12 AM
    bobc
    bobc [OP] Member
    Hi I've been lurking here awhile looking for advice on building my 04 Tacoma, and recently bit the bullet and ordered a toytec 3'' bilstein lift kit( from big country customs in Canada) now it arrived yesterday and i opened it up to check contents, the kit came with 2 bilstein 24-248730 front shocks that are listed on the bilstein site as for a 4-runner not a Tacoma! Will these fit my Tacoma?, The kit also has 2 F4 BE5-D560-TO rear shocks that are listed as rear passenger side for the Tacoma , will these work on the driver side also?
  2. Jun 1, 2018 at 6:15 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Contact @Toytec Lifts and see what they say. They are quick to respond on the forum. Good luck.
    FirstTimeFirstGen likes this.
  3. Jun 1, 2018 at 8:27 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    depends on year of 4runner. If its s 3rd gen 4r it will work. Rear shocks should work too. If I recall 1st gen Tacoma have longer shocks on one side stock, to compensate for taller spring
  4. Jun 1, 2018 at 8:32 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    The driver said has a taller shock but that doesn’t really matter once your suspension has been worn out some. But i think most after market companies just give you the same shock for both sides in the rear, i could be wrong though
  5. Jun 1, 2018 at 8:44 AM
    pairodice
    Jay
    SF NM
    You are correct sir
  6. Jun 1, 2018 at 8:48 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Im actually non sure of the drive side is taller or just stiffer with shocks valved diffrent. Ik after market leaf packs are still side specific but I thought one was just stiffer
  7. Jun 1, 2018 at 8:59 AM
    pairodice
    Jay
    SF NM
    just 1in taller to compensate for driver and fuel tank
  8. Jun 1, 2018 at 9:07 AM
    bobc
    bobc [OP] Member
    I just got this response from BCC :"Hey Robert , no those are the correct parts , 1st gen tacoma and 3rd gen runner can use the same struts , ucas , cam bolts etc over the years bilstien has added more numbers to there inventory so if 1 is on b/o we generally have 2 others to choose from for stocking that will fit the same application , rear shocks we stock as the same number they are the same for valving and dimensions for both sides .
    you will see that as you pull off your factory rear ones . all aftermarket companies follow the same suit , toytec , procomp , bds , fabtech etc with having the same part number for rear shocks .. hopefully that clears things up for you .."
    Does this response seem to be legit? I checked specs on the front shocks on the bilstein site 24-248730(4runner) collapsed length 13.66'' ext length 18.27'' vs 24-249928 (tacoma)collapsed length 13.86'' ext length 18.67''
  9. Feb 23, 2025 at 10:39 PM
    Jetski4x4
    Jetski4x4 New Member
    2004 Tacoma
    Did the shocks end up fitting ? Found a good price on some 248730 but I got 04 Tacoma wondering how it worked out for you ?
  10. Feb 23, 2025 at 11:41 PM
    02hilux
    Planet: EARTH
    24-248730 will fit. Difference between 24-248730 (4R) and 24-249928 (taco) is collapse and extension, but not by much. If the price is that much significant of a saving between the 4R and Taco, then you can run the 4R 5100s. If it's not by much, grab the correct set for your truck.
    24-248730:
    Extended Length (in): 18-1/4 Inch
    Compressed Length (in): 13-11/16 Inch
    24-249928:
    Extended Length (in): 18-11/16 Inch
    Compressed Length (in): 13-7/8 Inch
    Jetski4x4[QUOTED] likes this.
