Need advice on truck making a noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by faceplant, Jan 31, 2014.
  1. Jan 31, 2014 at 4:48 PM
    faceplant
    faceplant [OP] Well-Known Member
    Kingston,TN
    06 trd
    ok the truck started making noise about a week ago. I did a water crossing no to deep but probably half way up the tires/bottom of front bumper. well the truck started with a screeching noise or a winding noise. thought it was the belt up front but when i get out to listen while idling no noise. i hear the noise when I'm going about 40 and above and when i stop or slow down it goes away. also sounds like its in the back but i don't think its the brakes. Thanks for any help
  2. Jan 31, 2014 at 4:51 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Start by checking your rear differential fluid. If the fluid is milky change it right away because you got water in there. The breathers are placed on top of the housing, which is a bad place for them if you do water crossings. Bearings and water dont mix.
  3. Jan 31, 2014 at 4:51 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Drain your rear differential and see if any water comes out.
  4. Jan 31, 2014 at 4:52 PM
    faceplant
    Kingston,TN
    06 trd
    yeah thats my next thought. i didn't want to hear that
  5. Feb 1, 2014 at 3:46 PM
    nguyas
    nguyas Active Member
    California
    2005 TRD tacoma
    Toyos have problems with differential.. I just changed mine... starts with screech and gets worse.. check it out before it gets worse.. you can make it worse.... Stealership charges about 2800. for the whole thing .. I went to yotamasters. Too far for you, but they can give you ideas, help and parts if needed....
  6. Feb 2, 2014 at 8:01 PM
    faceplant
    Kingston,TN
    06 trd
    ok so i change the rear diff oil and still have a low noise going on some where. its driving me nuts. any more advice
  7. Feb 2, 2014 at 8:04 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Was the oil milky when you drained it?
  8. Feb 2, 2014 at 8:05 PM
    faceplant
    Kingston,TN
    06 trd
    no not really. maybe just a little but i think the oil was just older bc just bought it a few months ago not sure when the old owner changed it
  9. Feb 2, 2014 at 8:09 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    If it wasn't milky that means there wasn't water contamination. It might be a wheel bearing. Do you have a go pro or access to one?
  10. Feb 2, 2014 at 8:10 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Lift up the rear axle, spin there tires(with your hands first), see if you can hear anything. Maybe there's something caught up in the brakes.
    Could also be a ujoint squeeking. All the grease could have washed out. Pull off rear driveshaft and see if anything is seized or squeekin.
    Without hearing the noise it's very hard for us to pinpoint.
  11. Feb 2, 2014 at 8:11 PM
    faceplant
    Kingston,TN
    06 trd
    no afraid not. no friends with any either
  12. Feb 2, 2014 at 8:12 PM
    faceplant
    Kingston,TN
    06 trd
    ok ill try that.
  13. Feb 2, 2014 at 8:27 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    If you can't hear anything when spinning the tires while jacked up, you can pull the rear drive shaft and drive around in 4wd. If it still makes noise it isn't the shaft.
  14. Jun 15, 2014 at 4:24 PM
    weechotij
    weechotij New Member
    Luis
    Texas
    TRD Sport
    did you ever figure out the source of the noise?
  15. Dec 31, 2014 at 11:44 AM
    OneWheelDrive
    OneWheelDrive Well-Known Member
    Peter
    San Diego/Encinitas
    2012 DBL Cab LB TRD Sport
    I'm going to revitalize this thread as I'm having the same issue. Dropped a jet ski at via beach launch and was pretty deep in salt water for a while. Taco is at service center where they also couldn't diagnose the issue.... I suggested rear diff as a possibility and they're going to do the rear diff service for $100. We'll see...
  16. Dec 31, 2014 at 11:59 AM
    OneWheelDrive
    Peter
    San Diego/Encinitas
    Checked all wheel bearings and they were fine. Only 36,000 miles on the truck.
  17. Dec 31, 2014 at 7:07 PM
    OneWheelDrive
    Peter
    San Diego/Encinitas
    Pretty close to that sound actually. Dealer serviced the rear diff and found no water. Is that sound the front wheel bearings?? Like I said, dealer checked and found no play and said they were "good".
