need advice replacing struts on 07 taco
Discussion in 'Suspension' started by Cookie, Jan 10, 2012.
  1. Jan 10, 2012 at 3:23 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I get the principle of what shocks do and even said, in an extreme case they might affect tire wear but they would have to be providing almost no resistance meaning the shock would be acting as a coil guide and that's it (even then I'm not convinced it would wear the tire unevenly). Alignment, balancing and tire pressure have a much bigger influence on tire wear than the shocks. If those 3 things were done correctly, driving around with blown shocks is more of a safety issue than a tire wear concern. The coil keeps the tire planted, the shock only absorbs the rebound from the coil when you hit a bump in the road. I could be wrong, but I'm not seeing it... :notsure:
    Edit: Brett's post got me to dig a little deeper into the interwebz...
    http://blog.nwautos.com/2009/05/cupped_tires_are_real_--_and_a_real_danger.html
    YotaTaco, you win this one :eek:
  2. Jan 10, 2012 at 3:29 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    The British use the correct term for shocks...dampers.
    They dampen the energy exerted by the tire reacting to irregularities in the road and dampen the rebound of the spring.
    Brett...what's your connection to Wild Ginger?
  3. Jan 10, 2012 at 4:19 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I'm a bit of a wild Ginger myself, and unfortunately my only connection to the real Wild Ginger is the fact that I love their food!
  4. Jan 10, 2012 at 5:02 PM
    YotaTaco
    YotaTaco Well-Known Member
    07 Taco 4WD Base Blue SR5 TRD OFF-ROAD! - SOLD, 2017 OR AC
    Pugga ~ Touche. So does this mean you have to make me a sammich?
    Wild Ginger = so delicious! Yum!
  5. Jan 11, 2012 at 5:32 AM
    Pugga
    Massachusetts
    :sandwich:
    :anonymous:
  6. Jan 11, 2012 at 11:46 AM
    thinkingman
    redmond WA
    Dang it!
    Thinking I had a hookup.
  7. Jan 11, 2012 at 10:54 PM
    YotaTaco
    :drunk: I've been looking for an excuse to use this one!!
  8. Sep 21, 2013 at 9:02 PM
    Patrge06
    Patrge06 New Member
    Bill
    NY
    06 access cab 5 speed 2wd
    grill guard, cap
    The rt front shock is leaking on my 06 2wd access cab.
    The service mngr called it a "strut".
    I am looking for info on replacing both sides.
    Is this a DIY project?
