Need advice, spring strut and coil spacer
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95Sr5Chris, Oct 8, 2011.
  1. Oct 8, 2011 at 7:59 AM
    95Sr5Chris
    95Sr5Chris [OP] Active Member
    CT
    1995 Tacoma Sr5
    Yesterday i installed the AAL on my truck, looks great, now im trying to install OME 881 coil with top plate spacer.... I cannot seem to get the new spacer and shock iono place. obviously its bigger then my stock one. im prying down the the control arm and just cant get the damn bottom bolt to line up.!
    Please help guys. im at a stand still, anything else i should do
  2. Oct 8, 2011 at 8:10 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Try also stepping on LCA. Had fun getting my 885s in too.
  3. Oct 8, 2011 at 8:31 AM
    95Sr5Chris
    CT
    1995 Tacoma Sr5
    do i need to remove the upper ball joint from the A arm? .. im pushing down as hard as i can, idk what to do:mad:
  4. Oct 8, 2011 at 8:39 AM
    4Wheelin4Banger
    Randy
    We didn't. Is your LCA reconected? You could try slipping a wrench between LCA bolts on spindle so when you push down LCA goes down farther.
  5. Oct 8, 2011 at 9:09 AM
    95Sr5Chris
    CT
    1995 Tacoma Sr5
    it will not line up. man this sucks, i have a crow bar in there and everything
  6. Oct 8, 2011 at 9:13 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    You can try compressing the spring to make it a bit smaller then taking off the spring compressor after you get in between the control arms
  7. Oct 8, 2011 at 9:46 AM
    Robm
    Robm Member
    Rob
    Seattle
    02 Xtra cab SR5
    Ome 881 Coils and struts
    Did you disconnect the sway bar? That helps. Also, you can disconnect the upper control arm at the ball joint and that makes it very easy.
  8. Oct 8, 2011 at 12:10 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    yea disconnect the sway bar at the lca, use a small jack and push the uca down at the same time have a partner help you out.
  9. Oct 10, 2011 at 10:29 AM
    4Wheelin4Banger
    Randy
    Well are you lifted?
