Need Advice - Stuck alans wrench bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wilsonpj, May 7, 2010.
  1. May 7, 2010 at 9:45 AM
    wilsonpj
    wilsonpj [OP] Well-Known Member
    Pete
    Boulder, CO
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    So I have 2 alans wrench bolts from the top mounting brackets on my brush guard that are stuck. For the life of me I can't get them off and are close to stripping.
    Is there a shop like Midas or something I can take it to to have them removed?
  2. May 7, 2010 at 9:48 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Can you get a pair of pliers around the head of the bolt or is it sitting flush in the hole?
  3. May 7, 2010 at 9:53 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    take a pic of them
  4. May 7, 2010 at 9:54 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    try a little bigger size allen wrench...
  5. May 7, 2010 at 9:58 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    piece of cake...bolt extractor kit from sears.
  6. May 7, 2010 at 9:59 AM
    wilsonpj
    Pete
    Boulder, CO
    2006 DC, SB, OR
    flush as can be. i'll look at that bolt extractor kit
  7. May 7, 2010 at 10:00 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    lots of times when i run into this I can usually fit the tip of a flat head or square head screw driver in the it to get it out also.
    let this be a lesson to you... brush guards are good for nothing :p
  8. May 7, 2010 at 10:03 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
  9. May 7, 2010 at 10:08 AM
    aficianado
    back to bone stock.
    FLUSH??!!! oh..bolt extractor may not work. you have a pic?
  10. May 7, 2010 at 10:21 AM
    wilsonpj
    Pete
    Boulder, CO
    2006 DC, SB, OR
    no pic till later.
  11. May 7, 2010 at 11:30 AM
    wilsonpj
    Pete
    Boulder, CO
    2006 DC, SB, OR
    Picture is uploaded in my gallery....
  12. May 7, 2010 at 11:45 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    that looks like a torq head bolt to me
  13. May 7, 2010 at 11:47 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    thats alan, i would try a flat screw driver that is the same size
  14. May 7, 2010 at 11:48 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    May consider screw extractor if it's not too big of a bolt..Otherwise try just drilling it out.
  15. May 7, 2010 at 11:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What happens when you stick the allen wrench in there?
    What I mean is....does the allen wrench go down into the hole of the bolt head entirely? If not, tap it with a hammer to get it to go deeper in the bolt head. Then, HOLD it in there while you try and pry on it. I'm guessing this won't work, but thought I'm mention it.
    Do you have the proper sized allen wrench (metric or standard)??
    The next thing I would try....
    What is that spacer looking thing behind it? Can you get a vice grip on that and turn it? If you can get that thing to move, you might be able to get the bolt to move.
    What's on the other side of the bolt? Can you get in there with anything?
    Another option - Use a dremel or hacksaw and cut a straight line through the center of the bolt head (the whole way across). The whole idea, is to make a cut so you can get a flathead screwdriver to try and get it loose. Also - you'll have knotches there to use a punch or chisel on it also.
    If all that stuff doesn't work - use a bolt extractor (as already mentioned). However, for best results........you have to drill a hole into the center of the bolt and a deep enough hole for the extractor to work.
    If there's a nut on the other side - you might be able to just cut the head off completely and punch the bolt through the other side. But - be careful where the piece ends up....(if it gets stuck inside your frame and rattles around for years...that would suck).
    Sorry, I'll shut up now....
  16. May 7, 2010 at 12:34 PM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    lmao
  17. May 7, 2010 at 12:38 PM
    wilsonpj
    Pete
    Boulder, CO
    2006 DC, SB, OR
    That is an alans, i have the correct size wrench, it goes in all the way. The "spacer" looking thing in the back is the left over part of the upper support brace that snapped off and was left behind.
    The problem is i am trying to put so much torque on it to loosen it, its at the point where the head is about to be stripped.
    I've been spraying liquid wrench on there every few hours, i'm gonna let that soak for a while and try again later.
    To make things worse, it is in a tight spot and on top of that I have a cast on my arm from a broken wrist so it is tough to get two hands in there for support.
    Anywho, thanks for all the ideas, I'll keep at it.
  18. May 7, 2010 at 12:57 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    you probably just need to sell the truck now...you're never gonna get it loose.
    JK
    Go buy a cheap set of 3/8" drive ALLEN (not alans) sockets and take one that's slightly larger and pound it in there with a hammer. Then make sure you hold it tight and use plenty of leverage (a pipe extension) or an impact gun if you have one. If that doesn't work then you will need to drill it out and use a bolt extractor.
  19. May 7, 2010 at 1:27 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    x2
