Need advice! transfer case chain slipping bad!
Discussion in '1st Gen. Tacomas (1995-2004)' started by xxOkieTacoxx, Mar 16, 2015.
  1. Mar 16, 2015 at 6:17 PM
    xxOkieTacoxx
    xxOkieTacoxx [OP] Well-Known Member
    Jake
    Texarkana, TX
    99 Tacoma SR5 3.4L 4x4/ 16’ DCLB TSS
    3.4L V-6 W/ custom intake,Flomaster super 44 dumped, 15" Incubus Alloy Wheels W/33x12.50 Yokohama Geolander MT'S, Bilstein 5100 Adj W/ OME 881coils, Pro Comp rear leafs W/ Bilstein 5100 shocks, Manual Hubs, Diff. Drop,Custom front bumper w/ winch W/ keyed disconnect and 2 250,000CP running lights, relocated blinkers, front bumper removed, radiator guards, custom skid plates, Rhinolined interior,
    I have a 99 taco with the v6 and auto trans. With manual hubs. I posted awhile back about a bad noise I was hearimg when I would get the fwd under a load. I jacked all four wheels up and had someone sit I'm the truck to work the gas and brake while I listened and looked. The only way I can get it to make this noise is when I get the wheels up to speed and quickly hit the brakes stopping the tires while the drive is still under power. The horrible noise I was hearing was I'm fact from the transfer case and the pinging noise I was hearing was the rear drive shaft, since its hollow any grinding noise from the transfer case resulted in it echoing through the drive shaft. My question is. Can you replace the sprockets and chains inside? I'm assuming my chain has stretched and I figure I've ate up the sprockets too. I will be doing the work myself and have access to a good shop. Trying to do this the cheapest route possible. Any help appreciated.
  2. Mar 16, 2015 at 11:38 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    69 views... No replies.. Nicee
  3. Mar 16, 2015 at 11:41 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    You should have your transfer case rebuilt that's the only solution I can think of.
  4. Mar 17, 2015 at 12:17 AM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    trail gear just came out with a gear driven transfer case. its called the verso. its not cheap but its really nice and strong. its on my list of future mods lol
  5. Mar 17, 2015 at 4:15 AM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
  6. Mar 17, 2015 at 8:24 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    If it has been slipping for awhile,,you have probably circulated metal chips thru out.
    Full tear down and inspection of all components and make a parts list on what you find and need. Both in and out bearings and seals, case gaskets, ect,,to start off with,,then whatever else you need when you get inside.
    Your cheap budget kinda goes out the window when you do something like this. You might find that everything is trash inside minus a few small pieces, so be prepared for a junkyard run.
  7. Mar 18, 2015 at 5:37 AM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Thanks all. I ordered that off of eBay. Priced the chain alone through the deal and was like 600 bucks. I plan on tearing it down somewhat and replacing seals and gaskets. Hopefully nothing else too major. I kinda am starting to doubt it though. There is a lot of components inside that tcase.
  8. Mar 18, 2015 at 10:47 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    What did the fluid look like, and what kind of noises did it make in 4wd on all 4's under power? How much play is in the f/r outputs? How are your u joints and rear cv?
  9. Mar 19, 2015 at 6:23 AM
    CR, WA
    stock
    One year when we went Elk hunting we drove a old Suburban that had a slipping chain. A couple steep grades with some hard chain slips was all it took to strand us waay out there. It obliterated the teeth off of the gears and reduced the chain to a cheap bunjie. Little did I know that the t-case was bad,,or I would have drove myself.
    Was reported that big shavings and chunks were found when the case was split. It was ugly I guess.
    Once you hear those cases clunking that chain,,park it asap and fix, or baby it home, or be towed. You'll stand a better chance at saving money.
    So long as the first indications look good, I would just run that ebay case first before splitting it open. Fresh oil and let it rip.
  10. Mar 23, 2015 at 5:34 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    I have the FSM for my truck, I've read over the transfer case components list and the seals I will need to replace once I have it tore down even got the Toyota fipg gasket maker. My ujoints and CV joints are all good. Its definitely coming from the tcase. Plan on breaking it down this weekend and going through it really good to make sure I get all of the metal shavings/chunks out. When I had all 4 wheels jacked up and had it in Fwd it doesn't make a sound unless I apply heavy braking to slow down the wheels before the drive train can slow down. I plan on taking the oil pump apart as well and Checking it for metal and smooth operation. This should be interesting to say the least.
  11. Mar 23, 2015 at 5:43 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
