Need advice troubleshooting headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04Tacoma20, Mar 14, 2023.
  1. Mar 14, 2023 at 5:26 PM
    04Tacoma20
    04Tacoma20 [OP] Member
    2004 TRD Off-road Prerunner, 2020 TRD Off-road
    My 04 Tacoma headlights will not illuminate when switch is turned to on position but the daytime running lights work fine and headlights light up when stalk switch is pulled into the flash position. The fuses and relays checked good and I replaced the stalk switch. Any troubleshooting advice would be appreciated.
  2. Mar 14, 2023 at 5:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do the High beams work if you set the lights on High?
  3. Mar 14, 2023 at 5:49 PM
    04Tacoma20
    No, no high or low beams
  4. May 28, 2023 at 2:06 PM
    04Tacoma20
    Update: Problem resolved. I ended up replacing the Body ECU (fuse/junction-block assembly).
    Madjik_Man likes this.
