Need advice with AAL size with 3" front spacer lift
Discussion in 'Suspension' started by BornHi, Mar 1, 2011.
  1. Mar 1, 2011 at 10:08 PM
    BornHi
    BornHi [OP] Well-Known Member
    TJ
    Kauai
    2010, 2.7L 5speed 4x4
    5% tint all around and 50% windshield, Hell bent steel 1-1/4 leveling kit, aftermarket fog lights, DTRL switch mod, Rear Diff. Beather mod. Total Chaos UCAs.
    I have a 2010 Tacoma Access Cab 4x4(2.7L) with Hell Bent Steel 3" Spacer lift.
    I was wondering what size AAL should i purchase; so that my truck still sits leveled, and that the back of the truck is not higher than the front?
  2. Mar 2, 2011 at 6:21 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    2" AAL will get you level.
  3. Mar 2, 2011 at 6:44 PM
    BornHi
    TJ
    Kauai
    Thanks for the info. KPT
  4. Mar 2, 2011 at 6:48 PM
    jandrews
    '09 FourDubDee TRD OR
    Any reason you want to level? You know as soon as you load the bed you're going to sag in the ass right?
  5. Mar 2, 2011 at 7:14 PM
    BornHi
    TJ
    Kauai
    Yeah i know it will sag. But i don't haul around heavy loads. Just want my truck to look level.
  6. Mar 2, 2011 at 7:27 PM
    BornHi
    TJ
    Kauai
    ^^^Yeah, i was just thinking about that. Measuring the distance and then decide from there which size AAL i should get. Thanks for your info. It helps me alot to get different opions.
