Need Advice
Discussion in 'Suspension' started by UofA Taco, Mar 9, 2010.
  1. Mar 9, 2010 at 4:49 PM
    UofA Taco
    UofA Taco [OP] Well-Known Member
    Blake
    Auburn, Alabama
    2010 Double Cab 4x4
    K&N filter 3" Toytec lift
    I'm currently running 5100's up front @ 1.75 and had the tsb done about three weeks ago on my 2010 double cab. I'm thinking about purchasing the Toytec 3" lift with front coils & aal. Do I have to change the settings on my shocks or would you recommened leaving them at 1.75. I want the truck as close to level as possible.
  2. Mar 9, 2010 at 4:55 PM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    with ome coils you set the billy's at 0.
  3. Mar 9, 2010 at 5:02 PM
    UofA Taco
    Blake
    Auburn, Alabama
    2010 Double Cab 4x4
    DAYYUMM love the truck ^^^^^^^^:thumbsup: Having any trouble with alignement @ 2.5?
  4. Mar 9, 2010 at 5:14 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Why are you getting the three inch kit when you already have the Bilsteins? If you want three inches, just set the Bilsteins at the top notch (2.5") and get 10mm topspacer kit. Better setup, and less money. Then just need a single AAL kit or a 3leaf AAL kit (depending on how you use your truck).
  5. Mar 9, 2010 at 6:38 PM
    UofA Taco
    Blake
    Auburn, Alabama
    2010 Double Cab 4x4
    I've just heard about alignement issues with Billy's @ 2.5 I really dont have a place or tools to do the work myself, so I wasn't sure if taking taking the shocks off, re-setting them, and putting back on would cost the same as adding the coils or not. Sorry I'm new:eek:
  6. Mar 10, 2010 at 5:58 AM
    CAMZTRD
    steve
    hampton, va
    thanks, i have Light Racing UCA's to correct my alignment..
  7. Mar 10, 2010 at 7:03 AM
    UofA Taco
    Blake
    Auburn, Alabama
    2010 Double Cab 4x4
    How long could I run the Billy's @ 2.5 with a 1/4 spacer without different UCAs before it starts to wear on the tires too much. I mean I'd eventually get them to help out alignement but cash is kinda tight right now.
  8. Mar 10, 2010 at 9:12 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The Alignment issue is when you do any kind of suspension lift at about 2.5"+. It is NOT a tire wear issue. It is a drivability issue. The caster gets low and the vehicle will tend to wander. A lot of people don't mind it and drive it how it is. And a lot of people decide to get the UCAs to bring the caster back up.
  9. Mar 10, 2010 at 9:43 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    It won't affect your tire wear. Just drove me crazy(pun intended)! You can go without them but if you got the cash they are deffinately worth the money! You can get the lr uca's at www.fatbobsgarage.com for around $370.
  10. Mar 10, 2010 at 1:12 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    As long as you want!
    If you go to a good alignment shop, they should be able to get the alignment into specs to where you don't wear tires.
    But the UCA's are the way to go!
