Need advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baboltin, Feb 26, 2024.
  1. Feb 26, 2024 at 4:08 PM
    baboltin
    baboltin [OP] New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    So I’m getting my 2019 DCLB Tacoma next week
    All stock beside a camper shell on it.
    I have read over a ton of different post about lifts/tires and wheels and feel more confused then when I started. I will use the truck for a daily driver as well as a hunting rig. My previous Toyota Tacoma (2009 DCLB) had a camper shell as well and I put uca and bilsteins with a coil to get the lift I wanted which was level. I was running a 285/70-17r on it but it rubbed.
    with the new truck I am wanting to run either 275/70-r17 or 285/70-r17 without rubbing, what does everyone suggest as far as a lift and wheel set up?
    From what I have read it seems as though what would work best for me is a bilstein set to maybe an inch lift with stock coils since from what I have read aftermarket coils are not suggested and then to put a level lifting block in the rear.
    Am I on the right track? What are your suggestions? Do I need a leaf spring in the rear with the camper shell? And should that be how I get the lift in the rear instead of a block? And should I replace the bump stops ? Thanks everyone trying to figure out what all I should and need to order once I get the truck to mod it.
    also forget to mention at some point I want to put a rear bumper on it with a swing gate and wheel on the rear as well as skid plates and a front bumper that is fitting in the center of the stock bumper with a winch. Also my last question from what I have read a lot of guys add one more clip to there shock on the driver side to get it level from driver to passenger side if I go with the bilstein shocks would that be suggested ? Sorry for all the questions.
  2. Feb 26, 2024 at 5:08 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I would run 6112/5160's icon rxt stage 2, or stage 3 if plan on carrying 200lb or more constantly. 0 to +4 offset 275's hit or miss on 285's rubbing. UCA's optional remember good alignment shop is key, max out Caster to clear body mount. My 2 cents. Sure there will be more chiming in.
    908tacoma and baboltin[OP] like this.
  3. Feb 26, 2024 at 6:00 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Thank you and looking forward to see what everyone else has to say.
  4. Feb 26, 2024 at 6:13 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    OME medium or heavy load , new leaf pack , if you do new UCA can easily clear 285s with 0
    Offset or so ..no need for chop
    baboltin[OP] likes this.
  5. Feb 26, 2024 at 6:34 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    What shocks do you suggest? And what leafs?
  6. Feb 26, 2024 at 6:36 PM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    all OME .. EL111R leaf pack and nitrocharger shocks
    baboltin[QUOTED][OP] likes this.
