Need Advise... 6spd tranny problem after switching to synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TonyTacoTrd, Aug 31, 2011.
  1. Aug 31, 2011 at 9:42 PM
    TonyTacoTrd
    TonyTacoTrd [OP] Member
    Anthony
    San Diego, Ca
    06 TRD OR 6-spd 4x4
    some stuff
    OK heres the story. Got the 6 speed manual taco used and the tranny felt great except for a little buzzin shifting from 2nd to 3rd that only occurred when the truck was cold. Once it started to warm up it would quickly disappear.
    then i decided to make the switch to synthetic gear oil and went with some Mobil 1 full synthetic 70/90. I drained the old stuff out and pumped in the new, filling it with almost 2 whole quarts and it started spilling out the fill hole. Sealed it back up and thought i was done.
    I go for a test drive and the problem arises again. The same grindage between 2nd and 3rd but it is much more noticeable now and remains prominent until the truck is fully warm. (keep in mind that I am in So Cal and when i say cold its really not that cold haha)
    Here are my thoughts and questions:
    is the synthetic stuff to thin for the brute taco tranny?
    is it just taking longer to warm up?
    does oil have a break in period? It has been almost a week...
    did i put enough in? I added as much as i could, until it spilled out...
    Will swapping in some Redline or Royal Purple help?
    Any help would be greatly appreciated
  2. Aug 31, 2011 at 9:49 PM
    ser240z
    ser240z Well-Known Member
    Scott
    Monterey Park, CA
    09 Dbl Cab 4X4 6spd
    Could be too thin and/or maybe taking longer to warm up since it is more efficient. I had to have the dealer throw heavier gear oil in my 6spd sentra because it had the same problem going from first to second. The heavier oil made it shift much smoother.
    Hope this helps. Good luck.
    Scott
  3. Aug 31, 2011 at 9:59 PM
    TonyTacoTrd
    Anthony
    San Diego, Ca
    06 TRD OR 6-spd 4x4
    some stuff
    ya im also thinking that it is to thin. Im just curious if the expensive stuff like Redline is any heavier.
  4. Sep 1, 2011 at 7:37 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    No break in period for oil, shouldnt have to warm up, and I highly doubt a more expensive oil will cure what you're experiencing unless the oil specifies that it will attempt to resolve gear issues.
    My opinion...its an issue w/ the trans/gears/synchros. It doesnt sound like the new fluid made any change, one way or the other.
    Personally, if I was experiencing the problem, already changed trans fluid and I still experienced the issue, I would try a bottle of lucas trans slip fix stuff. Whatever its called. If that didnt do it, then I would look into fixing the actual issue, assuming it was bad enough to warrant the repairs.
  5. Sep 1, 2011 at 7:41 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Try some Redline Heavy shockproof LINK --> http://www.redlineoil.com/product.aspx?pid=44&pcid=8, if that doesn't help, you are looking on a new or rebuilt tranny.
    I put the Heavy shockproof into my friends temperamental 6speed tranny in his Nissan and it improved shifting by 200%!
  6. Sep 1, 2011 at 1:50 PM
    TonyTacoTrd
    Anthony
    San Diego, Ca
    06 TRD OR 6-spd 4x4
    some stuff
    thanks for the input guys. I was hoping that it wasn't a serious problem but i guess not... :(
    The weird thing though is that the problem surely became worse After I made the switch to synthetic...
    I guess my next move is trying some Redline Heavy ^. But I noticed the site says it isn't recommended for most synchro applications. Is it ok for tacomas?
  7. Sep 1, 2011 at 1:55 PM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
  8. Sep 1, 2011 at 2:14 PM
    05RedTaco
    Tony
    Scottsdale
    As I stated... We put it in my friends 2002 Nissan Sentra SE-R SpecV with 6speed synchronized transmission. He has been running it in his tranny for over a year with no issues.
  9. Sep 1, 2011 at 3:51 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Personally, I would switch back to oem fluid. See how it reacts, then if needed do an additive.
  10. Sep 1, 2011 at 4:00 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    2005 manuals are notorious for being pieces of shit. That's why Toyota quietly redesigned them for the 07 model year. Sme early 06s suffer from the same issues.
    More info here:
    http://ttora.com/forum/showthread.php?t=162445
    The fun starts on post #22.
  11. Sep 1, 2011 at 4:35 PM
    TonyTacoTrd
    Anthony
    San Diego, Ca
    06 TRD OR 6-spd 4x4
    some stuff
    holy balls that just scared me ^ and I am way out of warranty. Hope mine isn't as bad
  12. Sep 1, 2011 at 4:42 PM
    jandrews
    There's threads all over TTORA of 05 ManTrans crapping out.
    Seems like Aisin phoned in the early design. ToMoCo is aware of the problem, seems the response if under warranty is to fix with the new upgraded parts. No TSB that I'm aware of...just stealth repairs/replaced parts.
  13. Oct 15, 2011 at 5:50 AM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    08tacoma4x4 5spd 4cyl
    afe cold air intake,tornado fuel miser,body armor front bumper,dual magna flow exhaust,blacked out factory rims and fender flares,baja lights,cooper ATR tires,Gforce,hood scoop,peel n seal bed cover,chrome nerf bars
    I also changed to syn gear oil over a week ago. yesterday it wouldnt go n 3rd and this am it was hard to shift in all gears . once again if it came stock stick with it if it was good eneough from the factory its good eneough
  14. Oct 15, 2011 at 7:08 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    when its cold try double clutching from 1st to 2nd and see if it still happens
