Need advise on UCA's (Bilstein or Dirt King)
Discussion in 'Suspension' started by PRO1, Aug 30, 2023.
  1. Aug 30, 2023 at 1:05 PM
    PRO1
    PRO1 [OP] Member
    Miguel
    2020 White Tacoma TRD long bed
    3" front, 1" rear leveling kit, 17x7 wheels 285/70R17 Falken Wildpeak MT tires
    I currently only have a leveling kit on my 2020 Tacoma, I want to replace the UCA's but trying to see what's a better option for price, reliability, and longevity between Bilstein & Dirt King upper control arms based on experience? Trying to achieve a 3" lift using Fox 2.5 coil overs.
  2. Aug 30, 2023 at 1:26 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    There are a lot of UCA options, even between the two options you picked. So, it depends. Some things to consider are the bushings (polyurethane, heim joint?), ball joint (uniball, heim joints), thickness of the tube.
    I went Camburg because all things being equal, they were in stock.
  3. Aug 30, 2023 at 1:30 PM
    PRO1
    PRO1 [OP] Member
    Miguel
    I was looking at the Camburg and a coworker also has those on his truck, but I spoke with the mechanic who's going to do the work and he said it's much harder to get a true alignment with the Camburgs it this true based on your experience?
  4. Aug 30, 2023 at 1:48 PM
    rnish
    Tacoma 2nd gen
    No issues here. Again there are so many variables that can be customized just in one companies offering. It depends. Keeping it simple, I went with the poly bushings and grease-able X joint.
    I’m not a Camburg fanboy. I do like the product. However, I went with DirtKing LCA because they met my requirements and again were in stock.
    PRO1[QUOTED][OP] likes this.
  5. Aug 30, 2023 at 1:54 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    They are both similar. I’d get whichever is cheaper. I strictly remember when the bilstein UCA was teased they looked like a dirt king UCA with bilstein sticker. No idea if the two companies collaborated but after official release the bilstein product comes now with black bushing instead of red and the gussets at the bushing location changed from the diamond dirt kings type to what they have now. In the photos the bilsteins even have the typical moog ball joint same as dirt King runs so I doubt they are really any different.
    I ran dirt kings on a Lexus gx470 with zero issues.
    PRO1[OP] likes this.
  6. Aug 30, 2023 at 1:58 PM
    PRO1
    PRO1 [OP] Member
    Miguel
    Thanks for the info, really appreciate it.
  7. Aug 31, 2023 at 9:18 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    How bout JBA? Zero issues with mine.
