Need Alignment Spec Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DavidSmothers, Jan 25, 2024.
  1. Jan 25, 2024 at 12:50 PM
    DavidSmothers
    DavidSmothers [OP] Well-Known Member
    David
    Olive Branch MS
    2021 Tacoma TRD SPORT
    Getting a set of Cooper Road and Trail tomorrow and going to get the front end lined up.
    I’ve got Bilsteins front and rear with 2” of lift in front and 1” blocks in the rear.
    What front end specs should I shoot for?
    Since adding these UCL the steering seems twitchy that I don’t like.
    I know everyone says 3.5-4.0 on Caster.
    0.04 Toe and 0 Camber
    Does that sound like a general consensus?
    I Like the steering to be responsive but not super twitchy that every bump feels like your fighting to keep it straight.
    Thanks!!!
  2. Jan 25, 2024 at 12:54 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    More caster will help correct the issues you are describing. I believe I'm at 4 degrees and my truck is the straightest tracking and easiest vehicle to drive I've ever owned. Make sure the alignment shop you go to actually knows how to adjust the eccentrics and won't just get it tracking straight with tie rods.
  3. Jan 25, 2024 at 5:44 PM
    DavidSmothers
    David
    Olive Branch MS
    They are going to pull it up on the rack and tell me what it is before they change anything.
    They do the alignments for an off road shop in town so I’m hoping for the best!
  4. Jan 25, 2024 at 5:51 PM
    Bishop84
    Bishop84 Well-Known Member
    I cant tell what UCL is.
    With stock upper control arms you are limited to how much caster you can achieve.
    What you tell them is, max caster, balance camber, slightly higher toe in spec.
    You will be lucky to get 2 degrees caster with stock arms and a 5100 lift.
    Most shops will try to reduce camber and will sacrifice caster to get this, camber is tire wearing, caster is drivability.
    RustyGreen and 71tattooguy like this.
  5. Jan 25, 2024 at 6:01 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    My recommendation is to not overthink
    this and ask them to align to spec like any other alignment. There’s nothing special about your truck as far as I know. If they can’t get it into spec and it sucks to drive, then pick another shop, lower the ride height, or buy aftermarket UCAs (upper control arms) that have added caster and then try aligning it again
  6. Jan 25, 2024 at 8:15 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
