need alignment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Apr 8, 2012.
  1. Apr 8, 2012 at 11:10 PM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    So from my understanding I have heard that for everything I do to my suspension I need an alignment. If I install a 2" lift to my front and a ADD a leaf to the rear do I need a re alignment?
  2. Apr 8, 2012 at 11:11 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    SAS, dents, & scratches
    anytime you change the front you need a re-alignment.
    Rear doesn't matter.
  3. Apr 8, 2012 at 11:12 PM
    CayucosTacoma
    Alright that's what I heard. Just someone local said if it's under 2" I don't need one. Haha o well. How Micy is a realignment
  4. Apr 8, 2012 at 11:15 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    :eek: they are stupid.
    unless you like driving an unsafe, unstable, dangerous, hard to turn and tire eating truck.
    Micy? much is? pricey? lol
    depends on the shop, I believe around ~100 up here, dont really know :eek:
  5. Apr 8, 2012 at 11:17 PM
    VanCity4x
    VanCity4x The shit show
    DJ
    BC
    05 Prerunner SAS
    3link 1tons on 40's and sum stuff
    Just had mine done after new ball joint. Was actually off quite a bit. Gets it almost perfect. The best ones are the ones where they attach the camera to the hub and align it that way rather then from the size of the wheels. Was about $100, or a hour labour.
  6. Apr 8, 2012 at 11:26 PM
    CayucosTacoma
    Yeah much* auto correct on the phone. Damn 100? This loften is getting more and more expensive haha
  7. Apr 8, 2012 at 11:31 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    i think you can find it cheaper than 100..
    and youre from Cayucos?!
    parents live in Cambria. Don't know where you take your truck, but the little auto shop in cambria down in "tin city" is a great guy. Very knowledgeable, helpful, friendly, and FAIR. That guy was great! as soon as i bought my truck and took my old car to get a quick check up before we sold it he asked me to bring it in just to look at it and see if it needed anything (not to charge me but just to bask in tacoma glory and help me out).
    but im sure there are some garages down in SLO that would do it for a little cheaper than a hundred. Cheapest ive seen so far is 79...
  8. Apr 8, 2012 at 11:37 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    If there's a firestone nearby they offer a lifetime alignment as long as you own the truck and I've used it extensively since it was only 150 I've definitely got that much and more out of considering how many times I've changed shit and usually after I did any hard wheeling
  9. Apr 8, 2012 at 11:48 PM
    CayucosTacoma
    Yeah I live in cayucos! I might make the drive up to cambria then and see that guy. I'm not sure if there's a Firestone, I'll check on the internet
  10. Apr 8, 2012 at 11:59 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Les Schwab is like 60 bucks.
    Front will need aligned. Rear isn't "really" adjustable.
    If you change the front you more than likely should get an alignment.
    If you change the rear it's less important IMO, but it still will change angles so you might want to get an alignment again.
  11. Apr 9, 2012 at 5:36 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Lifetime Firestone- just so happens I have a good shop in my area :)
  12. Apr 9, 2012 at 7:34 AM
    logcabinwc
    Micah
    SF East Bay
    quick note... not sure if the guy in cambria has the machine to do the alignment... :/ but! they guy is great haha. so anything else you may want to try him out for, or at least give him a call to see if he has one or knows a good place to go :)
  13. Apr 9, 2012 at 9:15 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Raising the rear only affects caster angles. The camber and toe are unaffected.
    Firestone lifetime alignment= good deal.
