need all new suspension but everything is coated.
Discussion in '1st Gen. Tacomas (1995-2004)' started by kpla51, Jan 30, 2015.
  1. Jan 30, 2015 at 4:00 PM
    kpla51
    kpla51 [OP] Well-Known Member
    Fort Campbell
    Ok so I just recently got my 04 taco. Everything great except the suspension it is factory and has 160k on it. The rear leafs are completely flat and the shock bodys are rusted and falling apart. I would like to do an OME lift all at one time with new leaf packs. The truck was undercoated by toyota and they coated over every nut and bolt. Will this make it a pain to get these bolts off or is the coating easily broken free? They even sprayed the drive shafts and rim of the spare tire. Looks like they went nuts.
  2. Jan 30, 2015 at 4:44 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Undercoating is usually a rubberized compound that peels off fairly easily. You may have to get under there with a utility knife and slice it off of bolt heads and nuts so you can fit sockets on them, but it shouldn't be too much of an issue.
    They sprayed your driveshaft? What the hell man. Hopefully they didn't get so much of it on there that the balance is thrown off.
  3. Jan 30, 2015 at 4:52 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    How long ago was it coated? I would take it back and demand to have a clean spare tire!
  4. Jan 30, 2015 at 5:11 PM
    kpla51
    Fort Campbell
    Back in 2007 so a long time ago. They coated the underside of the gas tank and everything. They even coated the axles.
  5. Jan 30, 2015 at 5:12 PM
    kpla51
    Fort Campbell
    At about 70mph on the highway i felt a very slight vibration. Could be from a small imbalance or the old suspension.
