Need an Amp recommendation.....
Discussion in 'Audio & Video' started by DF23, Nov 23, 2015.
  1. Nov 23, 2015 at 6:56 PM
    DF23
    DF23 [OP] Member
    Central Florida
    '05 Speedway Blue
    4in Maxtrac Spindles 33x12.50 Atturo MT 18x9 Helo
    I plan on doing the following set up:
    -JL Audio sealed enclosure with two 10" subwoofers
    -power handling: 150-400 watts RMS (800 watts peak power)
    -Polk Audio db6501 component speakers
    -power range: 10-100 watts RMS (300 watts peak power)
    Can someone please recommend an amp that would power both the sub and the speakers? I will be replacing the stock headunit just don't know with what yet.
    Thank you...
  2. Nov 23, 2015 at 8:17 PM
    hexcentric1
    hexcentric1 Member
    Las Vegas, NV
    15 BR AC 4WD
  3. Nov 24, 2015 at 6:36 AM
    boltstaco
    boltstaco Well-Known Member
    eric
    oceanside, ca
    panty droppa
    AFE intake, 3" spacer w blocks in rear
    My kenwood xr900-5 does a good job and it's compact size
  4. Nov 24, 2015 at 6:47 AM
    gearcruncher
    Canadain bumper technician
  5. Dec 8, 2015 at 2:57 PM
    AMSFLVA
    AMSFLVA Active Member
    I have a JL XD 700/5 CHANNEL FS
  6. Dec 8, 2015 at 2:58 PM
    AMSFLVA
    jl sub 10" v3 also
  7. Dec 8, 2015 at 2:59 PM
    AMSFLVA
    my location FL, Lol if you are interested or in the market
  8. Dec 8, 2015 at 6:08 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
  9. Dec 10, 2015 at 10:26 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Here's my 2 cents - I've been running Alpine PDX's for 4 months now. They cook just about every day for two 40 minute commuting cycles, and I have zero issues with them. Doesn't matter whether the load is 4 ohm or 2 ohm, the power is current limited and it stays the same. These are tiny amps and they also sound really really really good and clear at low volumes. Don't run away from these because of the retail $500 price tag...you can get them in the low $300 range from Amazon, brand spanking new and normal stock (not crappy refurbs or scratched b-stock stuff) if you want to forgo Alpine's customer support. These are Class-D digital amps which sound like true Class AB amps. Also, they are very very power efficient and sip the supply current, which means your headlights won't dim or will only minimally dim.
    Alpine's still new PDR's, which are middle tier, are supposed to be based off the PDX's (as the current PDX 2nd Gen has been around since 2010)...they put out around the same power, but have slightly less SNR, and don't have quite the same fit/finish as PDX's. These cost about $50 to $100 less than the PDX's, and probably sound just as good.
    I've seen pictures of the current Alpine entry level amps, and there is nothing but free space inside. Big circuit board with not a lot of components (ie. basic power stages, filtering and overall amplifier design) I'd stay away from those.
  10. Dec 12, 2015 at 1:34 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I second mBrogz. I have a PDR-f50 and I love it. Never head a pdx, but I'm sure they rock too. PDRs are about the same money as PDX on Amazon right now. You won't go wrong with either.
