Need an answer. 33s on stock suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mthomas2, Mar 7, 2016.
  1. Mar 7, 2016 at 5:15 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Zactly
  2. Mar 8, 2016 at 6:48 AM
    mthomas2
    mthomas2 [OP] Member
    mike
    2005 toyota tacoma trd sport
    alright i tried putting them on last night the tire hits the control arm
    tire is genral grabber 33/12.50/17
    i got 2inch spacers and my 3inch lift coming will that make it clear
  3. Mar 8, 2016 at 6:56 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Took the words right out of my mouth if you want to properly fit a tire pull the shock fully compress the suspension to the bumps turn,turn, cut & repeat! That's if you want to really wheel it lifting it 3" does not change the bump placement unless your extending the bumps you will rub in the same spots stock or lifted of not clearanced.
  4. Mar 8, 2016 at 6:57 AM
    JLee
    Jerry
    Grass valley CA
    That's a wheel offset problem not lift the spacers should take care of that but it will put you into the cab mount for sure at full lock.
    mthomas2[QUOTED][OP] likes this.
  5. May 14, 2024 at 9:20 AM
    NoahBP
    NoahBP Member
    Noah
    2009 Tacoma TRD Offroad Silver
    Relentless fabrication front bumper with warn winch, and rci rock sliders
    If i cab mount relocate and hammer my pinch welds will 33's rub on stock suspension?
  6. May 14, 2024 at 7:14 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Nice job on searching and finding the thread but you failed to read the 24 posts within the thread that answer the question you’re asking. To save you 90 secs of reading: Yes.
