Need another 1" in the front...
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Dec 22, 2010.
  1. Dec 22, 2010 at 1:32 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So i have 5100 at the middle setting with OME coils and i need another 1" lift. You guys think i should do a top plate spacer or just raise the 5100's?
  2. Dec 22, 2010 at 1:53 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    What OME coils are you running?
    You are probably already at max lift.
  3. Dec 22, 2010 at 1:55 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yeah I thought you weren't supposed to run the billy's at anything over 0.85" with aftermarket coils....
  4. Dec 22, 2010 at 2:03 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    That's not a very good thread title.
  5. Dec 22, 2010 at 2:24 PM
    TexasTacoma37
    better than needing an inch in your rear.
  6. Dec 22, 2010 at 3:12 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    haha i have 881 coils right now. its defintaly ok to run 881 with the billys higher than 0" i defintaly researched and confirmed that.
  7. Dec 22, 2010 at 3:17 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    I put the 881's on and only got .5" of lift so i bumped the 5100 up to middle setting and i am still looking for a little more, but i am concerned about ride quality which is why i was considering the top plat spacer.
  8. Dec 22, 2010 at 5:14 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Damn, surprising you only got 1/2", with that same setup I netted ~1.9" after settling. I think something maybe wrong. How did you confirm they were 881's? You bought and installed yourself? Just checking, as this doesn't sound like a correct measurement. If all checks out, I would call ARB or the vendor you purchased the coils from and explain your situation.
  9. Dec 22, 2010 at 8:01 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Sounds more like 880s. You should get .5" simply by putting new OEM springs on since the old ones from '97 would've sagged at least .5".
    Everyone I've seen/read about are getting around 2" after settling with the 881s. So either yours arent 881s or something is screwed up.
  10. Dec 22, 2010 at 8:11 PM
    08chocotaco
    08chocotaco Well-Known Member
    TAYLOR
    San Diego/Los Angeles
    2016 Silver TRD Sport
    No current modifications
    get new springs maybe? oorrr, just a suggestion, go to stock spring and raise the billlys?
  11. Dec 22, 2010 at 8:11 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    that's what she said.
  12. Dec 23, 2010 at 8:13 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i went back and check my measurements again and i was actually able to get about 4 inches of total lift with the billys and OME coils which i confeermed as 881's. I used the wrong measurements to calculate my lift. everything is good and fine i will post pictures later :)
  13. Dec 23, 2010 at 8:46 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    That makes more sense
  14. Dec 23, 2010 at 10:31 AM
    TexasTacoma37
    That's more lift than the billys are rated for.
  15. Dec 23, 2010 at 12:18 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    so do you think i should lower the settings then? and just do a top plate spacer for my total 3"
  16. Dec 23, 2010 at 1:59 PM
    TexasTacoma37
    If the ome's and the billies at 1.75 gave you 4", I would at least drop the billy's back down to 0.85". That will get you just over 3" of total lift.
    Do you have aftermarket UCA's? How's your alignment with the 4"?
  17. Dec 23, 2010 at 2:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  18. Dec 23, 2010 at 5:58 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    there was no trouble aligning the truck with the 4" lift at all and the cv angles are great. if i drop the billys down to 0" and get a 1 inch top plate spacer i should have 3" of lift which is what i want. would that work? or do you think i should just leave it as is with the 881's and billys at the middle setting?
  19. Dec 23, 2010 at 6:01 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    this makes no sense at all 4" and good cv angles? good alignment? do you have pics by any chance? and or the alignment sheet?
  20. Dec 23, 2010 at 6:03 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Somethings wronge..cv's can not be good with 4" lift...
