Need answers before I start pls
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Infmous89, Jan 14, 2014.
  1. Jan 14, 2014 at 8:58 PM
    Infmous89
    Infmous89 [OP] Infamous89
    Glenwood spring CO
    05 tacoma sr5 sport
    Hey TW friends so I plan on doing 20" wheels with 33s graplers with a 3"lift.......will I knead to do any cutting ? How will my ride be ruff or smoothed ? Will it affect allot on my gas millage? :confused:
  2. Jan 14, 2014 at 9:24 PM
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    I had a 3" lift at first with 285/70/R17 (33") and the tires rubbed when turning but you can always trim. The smoothness depends on what kind of lift kit you are thinking of buying. Also the gas mileage will definitely go down with the bigger tires. I have a 6" lift with the same tires and my mileage went from 18 to about 13-15 depending highway/city
  3. Jan 14, 2014 at 9:30 PM
    Infmous89
    Glenwood spring CO
    05 tacoma sr5 sport
    Wat brand is yer 6"lift and how's the ride
  4. Jan 14, 2014 at 9:37 PM
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    How do you know what kind of lift to pick for smoothness ?
  5. Jan 14, 2014 at 9:41 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    If you have to ask about the lift, it's not smooth enough. For the smoothest lift, you'll just know man ... you'll just know.
  6. Jan 14, 2014 at 9:44 PM
    Tacoma Off Course
    Austin
    Houston, KS
    Stuff
    I mean lifting will make your ride rougher just some type of lifts are smoother than others.
    I am running MaxTrac 4" Lift Spindles w/ Bilstein 5100 Series Ride Height Adjustable Struts set at 1.75" of lift for the front. The rear is a 2.5" add-a-leaf (AAL) with 1.5" ProComp Lift Blocks and ProComp ES3000 Shocks. This will only work for 2wd though because the lift spindles only fit 2wd. The ride is fine to me but I don't mind a little roughness that comes with a stiffer suspension.
  7. Jan 14, 2014 at 9:45 PM
    Toyotamudbogs
    Devin
    White Springs , FL
    That answers my question thanks....
  8. Jan 14, 2014 at 9:48 PM
    Black Pipe
    Black Pipe Well-Known Member
    It will need some cutting for sure. Ride depends on type of lift you get. And yes it will effect your gas milage, anything that affects the drivetrain will change gas milage. These thread types come up about once every 3 seconds so please feel free to use the search button
