Need assistance changing a CV in OC, SoCal!
Discussion in 'Southern California' started by BeeRadd, Sep 10, 2012.
  1. Sep 12, 2012 at 11:32 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I don't think we need to remove the bearing assembly at all, do we?
    If you're going off that DIY, I think he just happened to be doing both for the purpose of the DIY. I think we can keep it in tact and just swap CV axles.
  2. Sep 12, 2012 at 11:44 AM
    BeeRadd
    BeeRadd [OP] Bought not built.
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    Yeah I was going off that DIY but i guess I mis-read it, well in that case, BOO YA!
  3. Sep 15, 2012 at 9:54 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    this still going on? have no idea where and what time?
    Brad sent u pm.
  4. Sep 15, 2012 at 11:10 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Pretty good instructions except for one thing, remove the large axle nut BEFORE you remove the tire with the vehicle still on the ground (if you can), that way you dont need to hold the hub from turning when you try to loosen it, that fugger is on there with the fury of GOD himself, lol.
    I have done 100s of axles in these things.
    Also, I am not that close to you at all but I do this stuff for a living, I can do it while you wait if you dont mind driving south for a while...I have a lot of OC customers that drive down to me all the time. I will do it for less than the shop you mentioned, but the drive will most likely kill the deal.
    Anyway good luck!
    PM if you want my help
  5. Sep 15, 2012 at 12:35 PM
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    NICE! Thanks for the info and help, We're going to get started in a little bit. Im looking forward to giving this a try. I don't have a tq wrench, not sure if MATT does either but I do have an impact wrench rated at 160 ft lbs so maybe If we don't have one I can just let that sucker tighten it up. Can I get your number in case we run into an issue or somethin?
  6. Sep 15, 2012 at 2:31 PM
    The Traveler
    SoCal
    How do you get to that axle nut with the wheel still on :confused:
  7. Sep 16, 2012 at 11:37 AM
    krans
    krans Well-Known Member
    Kenny
    Huntington beach/ West min duh
    09 Sport mall crawler
    Icon extended travel with resi front and rear,Camburg UCA, All pro standard leaf pack, Fogs anytime, General grabbers AT2,Custom stainless steel brake lines,bed box, Bestop soft top,50' light bar, amber rigid pods,CBI ditch mounts with LED pods,TRD intake,Anti dark hoodlights/rock light/LED whip,FX-R retros and Gibson catback..more mods to come
    Have you guys finished yet?!
  8. Sep 16, 2012 at 11:49 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    remove the hub cover...
    if yer wheels come with a center axle hub cover...
    that would need be removed as well.
    tho it can be done with the wheel off...
    just need someone to press the brake pedal
    while the nut is being turned off/on
    IMO... breaking loose the axle hub nut... should be the first step of order
  9. Sep 16, 2012 at 12:03 PM
    jandrews
    '09 FourDubDee TRD OR
    I would break it loose, but not take it all the way off so the hub and tire don't fall off when jacking the vehicle up. It shouldn't, but you never know.
    Anyway, either will work. If the vehicle's already on stands, just have someone stand on the brakes for ya.
  10. Sep 16, 2012 at 5:47 PM
    The Traveler
    SoCal
    UPDATE:
    We did the job yesterday with the help of Jimmy (stmpjmper). The axle nut came off with very little effort. I used a 20" broken torque wrench as a breaker bar, and barely made an effort before the nut broke loose. We torqued it back to 160 ft lbs.
    Only real difficulty we had was using the slide hammer Brad rented from Vatozone. It didn't come with the necessary attachments for the jaw puller, so we improvised with a set of pry bars. We ended up ripping the boot clamp off the front of the axle where it meets the front diff, and just used force until it slid out.
    Very educational experience! Thanks again, Jimmy, and let me know when I can stop by to drop off your 35mm socket! :D
  11. Sep 17, 2012 at 10:33 AM
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    Yeah sorry guys I seriously lagged on updating. Matt couldn't have said it better. Great stuff everything went pretty smoothly and it passed about 200M road test. Now I just have to test it off road :cool:
    Special thanks to Matt for helping me get it done on his birthday! I'm ready to pull another one off that was kind of fun. A hell of a mess though shit lol
