Need brake upgrade!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 043RZ, Nov 16, 2013.
  1. Nov 16, 2013 at 5:11 PM
    043RZ
    043RZ [OP] Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, 15" American Racing Wheels, 5.29 Nitro Gears, 35/12.50R15 Cooper Discover STT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Im having a bit of a problem with my rotors always warping within 10000 to 15000 miles. Iv replaced the rotors once with Napa rotors and within a short period of time, my steering wheel started shimmying back and forth every time i would apply the brakes. So i took them off and had them turned, and again, in a short period of time they would become warped.
    Why is this happening? Is it because of the larger wheels and tires?
    Iv been looking at the Tundra brake upgrade, but the thing is the brakes work just fine for stopping power and emergency stops. And trust me iv already had them all but lock up before. Had ABS kick on on hard dry surface so i know the brakes have plenty of power if the tires were starting to lock up in the front and ABS kick on.
    So are there any other options out there that you guys have tried and liked the results with. Thought about going with drilled and slotted rotors with hawk pads.
    Any suggestions? Thanks
  2. Nov 16, 2013 at 5:49 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    Napa stuff sucks. I had the same thing happen to me. Try a good set from summit racing I have a set of ebc rotors and they are amazing lasted me 40k so far and they really stop good. Get a set of those and the green scuff pads and your all set
  3. Nov 16, 2013 at 6:15 PM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    What type do you have? Are they drilled and slotted?
  4. Nov 16, 2013 at 6:18 PM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    What about Powerslot Frozen Rotors??? Never heard of them
  5. Nov 16, 2013 at 6:20 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    You can buy brembo's from eBay for cheap . I've bought a few through out the years and have never had any problems . There about 60 for a pair with free shipping .
  6. Nov 16, 2013 at 6:24 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    You may want to examine your brake calipers and see if the caliper moves back and forth freely. I see you drive where snow falls and the caliper may be subjected to road salts that can cause the mounting pins to seize. Also you may a bad front brake line that goes to the caliper, it can collapse on the inside and not show any external problems.
    Is the amount of wear on the brake pads equal on both the front and rear pads and the left and right side pads. You may find that to be contributing to your warping. I hope this may help. Good Luck.
  7. Nov 16, 2013 at 6:26 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    I have this set up they are great but hVe only had it for two months so can't stay say much for longetivity, they do squeak a big but I think I have to reapply grease on them.
  8. Nov 16, 2013 at 6:31 PM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Last time i had the wheels off (about a month ago) i checked the wear of the pads and everything looks to be wearing evenly.
  9. Nov 18, 2013 at 5:24 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Yes I do have drilled and slotted. Well worth the money. Not sure what ones I got but I'll try to find out for u. Ya also they are some what squeeky when I first jump in my truck after sitting out all night but after one good stop it's all quiet. Great set up definitly recommend it
  10. Nov 18, 2013 at 7:07 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Deck Plate Mod; Grey Wire Mod; 1.5" AAL; 1.75" Lift Shackles; Bilstein 5100's; Eiback Coils; LR UCA; Front Diff Drop; Tundra Brake Upgrade; Wheels Offroad Brake Lines; Rear Diff Breather Mod
    Tundra brakes are not too bad if you look around for some used calipers. Got mine off ebay and bought new slotted rotors and new pads. Cost less than $450. Great investment IMO.
  11. Nov 20, 2013 at 6:10 PM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Thanks for the info guys!!
  12. Nov 20, 2013 at 7:50 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Drilled/slotted rotors are really of no practical benefit. The holes add additional areas where the rotor is susceptible to cracking, and it also slightly reduces your pad contact patch. Regardless of what you find on the internet, they're entirely unnecessary - we've ran 14-25 hour races on regular blank rotors without burning rotors (24 Hours of LeMons and Chump Car endurance races with MR2s)
    The pads material is likely the cause of the squeak, not the rotor itself. An added benefit of Tundra brakes (or any larger brake system) is the larger mass to absorb and dissipate heat, but if you never get brake fade that may be unnecessary. I've read that the Tundra rotors last longer than Tacoma ones, but I've never ran them other than on my Tundra (which was fine for 3+ years without touching the brakes).
    Anyway, 2 cents to add to the pile. ;)
  13. Nov 21, 2013 at 3:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch Rugged Ridge 3" LED Pods w/Amber covers Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I see from your truck info that you have a lift installed. Did you adjust the rear brake proportioning valve (BPV) for the amount of rear lift you added?
    I ask because if you did not, the lift has cuased the rear braking to be reduced, forcing the fronts to do all of the work. Typically, front rotors will warp when overheated. This could explain why you are having trouble with the front brakes.
    If you have added 3" of rear lift, you must adjust the BPV arm upwards by the same amount to retain your front to back braking power.
  14. Nov 21, 2013 at 3:47 PM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Yes, the BPV has been adjusted. The lift kit came with a bracket to put it back in to specifications
