Need Bumper repair help. Hit and run victim.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Turp, Apr 3, 2011.
  1. Apr 3, 2011 at 12:53 PM
    Turp
    Turp [OP] Well-Known Member
    Virginia
    02 PreRunner SR5
    K&N panel/ snorkel removed Keyless, 2022 4Runner Wheels
    I need input/advice to see if I'm missing something if I attempt a repair. I have full INS coverage and will go that route first but if I will eat a deductable, I'm fixing it.
    At some point I have been the victim of hit and run. I found my bumper pushed in about an inch and it appears the damage is a faint dent and bent/flexed bracket.
    It appears I can remove and straighten the bracket. I would do so with a hydraulic press. What do you think? am I missing something? The valance may be scratched but I can repair pretty easy.
    Here are the pics
    Wheel:
    Bent bracket:
    Straight bracket:
  2. Apr 3, 2011 at 8:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Sounds like you got it figured out ok. The stock bumper is pretty flimsy and outrageously expensive to replace. Unfortunately it can be a challenge to fix it so it looks right again. Good luck with whichever route you choose.
  3. Apr 3, 2011 at 9:06 PM
    Turp
    Virginia
    02 PreRunner SR5
    Thanks.
    I'm going to talk to my INS agent and get some estimates. The worst is that the bumper was slightly dented. I might could press it out some but experience is that it is tricky.
  4. Apr 3, 2011 at 9:14 PM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    For the amount of damage, I'd avoid filing with insurance if you can.
  5. Apr 4, 2011 at 4:09 AM
    Turp
    Virginia
    02 PreRunner SR5
    I was thinking that too.
    Update: Decided to take a closer look. The brackets were actually not bent. The impact hust put a very minor twist in the bumper and knocked it to the extreme of its adustment. I loosened the brackets up and adjusted it back to within a 1/4". Other than the chafe marks on the valance, it's close enough for me.
