Need clutch Recommendations
Discussion in 'Performance and Tuning' started by cookee62, Feb 26, 2012.
  1. Feb 26, 2012 at 2:07 PM
    cookee62
    cookee62 [OP] Well-Known Member
    Lake Mary, FL
    06 DBL Cab
    URD SS, URD Y-Pipe, DTLT Headers, 3" URD Cat Back, Fox 2.5 CO, TC UCA, Fox Rear Resi, SS brake Lines, All pro 1.5" leafs, Halo Projector Headlights, WE Bead-lock Rims, 33 BFG AT, No Sway Bar
    Ok so I have read a little from prior threads but nothing really stood out. I know URD and centerforce.. Also heard of Expey. But noby really talks about the benefits of cost, Grab, Bite, Life etc.
    I do some pretty heavy offroading with some mud and loose sand and run anywhere from like 20 and some times 50mph. I want a clutch thats not too hard to use and has better bite than OEM. I want the life to be pretty good so I'm thinking a stage 2. Any help on this matter would be a great help. Reviews, likes, things like that. Thanks,
  2. Feb 27, 2012 at 10:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
