Need compatible locking gas cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RAD53, Feb 18, 2023.
  1. Feb 18, 2023 at 3:33 PM
    RAD53
    RAD53 [OP] Member
    Ruy
    2014 Gray Tacoma DCSB
    Mud tires
    Hi, Just curious if anyone has been able to find a locking gas cap that is actually compatible w/ a 2014 Tacoma pre-runner 4.0. I've gone through 4 different gas caps :Autozone,O'reilly's, Amazon, etc. & can't find any that haven't cause a MIL on the dash. Hope someone has had better luck. Thanks
  2. Feb 18, 2023 at 3:51 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    If you are having that many issues with aftermarket, might be best off to just go OEM.
    Will it lock? No. But you’re better off with someone pulling your cap to siphon fuel rather than drilling a hole.
    Hunter gatherer likes this.
  3. Feb 18, 2023 at 3:53 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I've had luck with Gates and Stant, but anything aftermarket is a gamble
    TnShooter likes this.
  4. Feb 18, 2023 at 4:43 PM
    Waasheem
    Waasheem
    2007 xrunner
  5. Feb 18, 2023 at 6:54 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    The STANT® locking cap fits & works -- but it can be finicky and sometimes cause the ECU to throw EVAP-related codes. Not all the time, just sometimes. If have or get a STANT gas cap & you get EVAP codes it's the first thing to check or try swapping out.
    To avoid the EVAP codes it helps to be sure to turn it extra-tight after it starts ratcheting.
  6. Feb 18, 2023 at 7:01 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  7. Feb 18, 2023 at 8:06 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    I've had good luck with MotoRad.
    Make sure to clean the "lip" of the filler neck.
    WD-40, silicone spray, etc. Even water will do.
    Try to reseat it a few times when new to let the o-ring settle in.
  8. Feb 19, 2023 at 6:42 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    My china made locking cap kept throwing codes....Put the original back on..
  9. Feb 19, 2023 at 7:01 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It’s pretty hard to get a hose down the filler into the tank due to the rollover ball that blocks the pipe. From what I understand, most gas thieves just drill a hole in the bottom of the tank.
  10. Feb 19, 2023 at 8:05 AM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    I used a q-tip and a bit of vaseline to grease the o-ring and ensure a good seal. Ive used this trick several times on cars over the years. Worked on my oem cap that seemed to be original to the truck. Also worked on the aftermarket locking one i bought from Amazon.
  11. Feb 19, 2023 at 8:16 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I really did not realize this was an issue with theft of gas…..
    With that thought I was under the impression we had non-siphon filler necks
