Need Confirmation Before I Pull the Trigger!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeverich, Nov 7, 2011.
  1. Nov 7, 2011 at 11:15 AM
    jeverich
    jeverich [OP] Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Okay - convince me to pull the trigger!
    2007 Access Cab, I4, 5-Speed
    I know, it's been asked a million times - now it'll be a million and one times.
    My intended setup -
    Bilstein Adj. Kit w/5100s & Eibach Coilovers from Toytec
    Rear AAL, w/5100s
    Diff. Drop & New Poly. Bushings
    Tires - 285/75/16 on Stocker Steelies, w/Spidertrax Spacers (will change wheels eventually...after Tanner Crab Season this Winter)
  2. Nov 7, 2011 at 3:19 PM
    upcountry
    upcountry Active Member
    Seattle
    07 Tacoma
    Strongly advise against spacers. Could fail and kill someone. See recent thread about being "stuck in fayettville". Guy had a wheel fall off after getting pjlled out
    . Also see spidertrax website which advises against use on highway....offroad only.
    If I put those on my truck and lost a wheel and killed someone I don't know if I could live with myself. Just pony up and do it right.
    Otherwise...setup lools good.
  3. Nov 7, 2011 at 3:25 PM
    upcountry
    Seattle
    07 Tacoma
    Just noticed your in narragansett RI. I have spent a lot of time surfing Monohans, the pier, and the lighthouse. I used to live behind charlieos for a few years.
    Your younger and looks like you fish....do you know my friend Evan Ellis? Has a boat out of somewhere near there.
    Also, your about my friends bros age..... do you know Matt Brady from wakefield?
  4. Nov 7, 2011 at 6:23 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Yeah, agreed about the spacers...
    Actually, living in Port Townsend right now.
    Used to surf the light house quite a bit, especially K 39, and Pilgrim Avenue. Really lights up if the conditions are jussssst right.
    Fishing out of Alaska for the foreseeable future, although both of those names sound familiar. Used to live right across from the Mews on Main Street in Wakefield.
  5. Nov 7, 2011 at 7:03 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Everyone may be shocked to hear this from me, but I say go for it. I loved my 2009 SR5 4X4 4cyl. With the mods you are plannig, I hope you are not in a hurry, that will be one pokey truck!
  6. Nov 7, 2011 at 7:11 PM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    With new gears in the rear it wont be sluggish
  7. Nov 7, 2011 at 7:16 PM
    sprgrey
    sprgrey Well-Known Member
    Grey
    Conroe, Tx
    TRD, DBL, TOYO w/KONIGS
    Many, the list goes on..
    I agree with the plans but agree with other guys about the spacers. They can cause problems. I also have 3 inch lift with 285/75/16 and fits fine w minor trimming but went with a rim that could accommodate. SO many decisions :frusty:
  8. Nov 7, 2011 at 7:18 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I have Spidertrax on 285/75/16 and have had ZERO issues
  9. Nov 7, 2011 at 7:50 PM
    upcountry
    Seattle
    07 Tacoma
    You could run a different tire size with a narrower tire and still get a 33" tire on there with the stock wheel and no spacer. Lots of guys run this combo without having to worry about hitting the upper control arm. Plus a narrower tire saves on gas and is easier for the 4bang to push. Check out the toyo m55....they have it in the metric equivalent of 33x10.5 which will clear the UCA. Can't remember the metroc soze..
    . Ill look for it
    BTW.....my wife worked at the Mews as the kitchen manager while she was in college at URI. small world. I live kn seattle now. Surf the strait frequently
    Twin rivers can be fun....little bit slow and underpowered
    But fun. Have you been up to Tofino?
