Need current info on bilstein adjustable shocks
Discussion in 'Downsouth Motorsports' started by Rider11, Oct 31, 2012.
  1. Oct 31, 2012 at 6:27 PM
    Rider11
    Rider11 [OP] Active Member
    Hope, Arkansas
    06 Dbl cab 4x4 4.0 manual
    33x12.50 Nitto Mud Grapplers- 18in Helo's
    I have a 06 4x4 it has an rear AAL and a front spacer not sure what size I am running 33x12.50R18 Grapplers and I need to replace the current shocks. Should I remove the spacer and run the front shocks extended or could I leave the spacer and only adjust front shocks like 1 notch above stock ride height to help clear tires a litte bettter not sure? And do I need the longer rear 5100's . Any info is appreciated. Is there still a TW price?
  2. Nov 6, 2012 at 10:17 AM
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Good morning,
    Sorry for the delay in responding..
    How much lift is in the rear with the AAL?
    Also we recommend you run one or the other as far as the spacer kit or the Bilstein 5100's...The reason being if you run the 5100's at the .85" setting and the spacer kit you already have you run the risk of the front end sitting pinned and the truck may not align.
    Let us know on the rear...
    Thank you.
