Need definitive answer about brake bleeding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Jul 1, 2017.
  1. Jul 1, 2017 at 6:50 AM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    i need to change front pads and I keep getting different opinions on whether bleeder should be opened when pushing Pistons back. It appears many TW members have had no problems not opening bleeder but I keep reading about abs damage that can occur. Can the board make a decision about the correct method. Tia
  2. Jul 1, 2017 at 6:52 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    No need to open bleeders if you have the right tool to push pistons back. Cheap ass tool too. I have used the screwdriver method several times and never opened the bleeders. Just take the lid off the master and go slow
    medic2230 likes this.
  3. Jul 1, 2017 at 6:53 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    I would open them, and just rebleed/flush the whole system with new brakefluid, not that hard to do
  4. Jul 1, 2017 at 6:59 AM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    I just went thru this issue this week. Didnt open the bleeder, got air in the ABS. There is a thread about it. Took lid off reservoir and used a spreader to collapse the pistons. Its your call on how you wish to do it but for me that bleeder will be open everytime from now on.
  5. Jul 1, 2017 at 6:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    I've done dozens of ABS equipped cars with no ill results. I just leave the piston side pad in place and collapse the piston with a C clamp. Slowly.
    All the chatter about stuff collected at the caliper is likely true. If you never, or rarely, service the brakes / change the brake fluid.
    If you do a full change of your brake fluid every couple of years as part of your basic maintenance routine (you know, like where you clean and service your brakes once or twice a year, depending on where you live and how you use the vehicle) then it's very unlikely there will be any sediment around to cause any problem.
    So that leaves the 'best method' to be dependent on the condition of the braking system.
  6. Jul 1, 2017 at 7:01 AM
    Bebop
    Nick
    How the hell do you guys get air in the systems with the bleeders closed? o_O
  7. Jul 1, 2017 at 7:05 AM
    Slow Internet
    Slow...
    Wiper Blades
    In my case I think some air was already in the system somewhere from PO. The pedal always felt a little spongey. Collapsing the piston just forced the air back and into the ABS. This is my best guess. I didnt open the bleeder just because I never have. I think my situation may have been an anomaly but still not sure. That is the part that is killing me, the uncertainty....lol
  8. Jul 1, 2017 at 7:27 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Of the thousands of brake jobs I have done, never once have I opened the bleeder to collapse the calipers. I know it makes it easier but it is not necessary. Heck with the Toyota brakes all you need is a small pry bar or big flat head screw driver to release the pistons.
    92PathSE and Bebop like this.
  9. Jul 1, 2017 at 7:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Another vote for not opening the bleeder. Changed my front pads a couple weeks ago and just pried back with a big flat head screw driver.
    Bebop and desertrunner24 like this.
  10. Jul 1, 2017 at 1:36 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I have never had a problem pushing the pistons back in on other vehicles...but on the Tacoma I ended up removing the calipers, and can't comment on the e
  11. Jul 1, 2017 at 1:39 PM
    mbrogz3000
    Northern NJ
    If you are concerned, you can pinch the soft line, then open the bleeder screw, then push the pistons back in.
    If you are doing a complete brake job and live in a cold climate, just take the caliper off altogether and once you put them back on, pump the brake pedal to seat the pads, the. make sure to flush the brake fluid with 1.5 L of good fluid (i.e., Toyota or Motul).
  12. Jul 1, 2017 at 1:42 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    o_O I guess you can't comment. :D
