Need detailed step by step help w/ changing brake pads/rotors
Discussion in 'Performance and Tuning' started by BAP_29, Jun 27, 2011.
  1. Jun 27, 2011 at 5:53 PM
    BAP_29
    BAP_29 [OP] Well-Known Member
    Ben
    North Carolina
    05 Prerunner DC TRD Sport
    Bilstein 5100s at 2.5" and Toytec 1.5" AAL Eagle Alloy 063 Wheels on 285/60/18 Cooper Zeon LTZ tires Alpine iDA-X305 Head Unit MB Quart DKD 116 Discus-Line 6.5" Front Speakers (Baffles by Marv) Alpine 6-Disk CD Changer Toyota All-Weather Floor Mats Kobalt Low-Profile Toolbox 13" Wicked Flow Muffler w/ Chrome Tip
    Tomorrow night I plan to install my new Hawk ceramic brake pads and new Powerslot slotted rotors. I've created this thread so that when I run into problems tomorrow night hopefully I'll have answers. I've read some write-ups and watched a few videos and I think I have a general idea of the entire process. I do have a few questions though:
    1. Do I need to take off the master cylinder cap?
    1. If I do take off the master cylinder cap so the fluid level can rise when I compress my pistons, will air get into my lines?
    2. By removing this master cylinder cap, is this going to prevent potential problems with damaging the ABS?
    Steps:
    1. Remove clips and pins
    2. remove master cylinder cap
    3. slowly pry back pistons with old pads in using a screw driver
    4. take out old pads
    5. insert new pads (grease the back of the pads)
    6. install the pins and clips
    Am I forgetting anything?
  2. Jun 27, 2011 at 6:29 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Dont forget the brake grease and the grinder. You will need to grind off all the old gunk from your rotors, then put a light coat of brake grease on the rotors to keep them from squeeling.
  3. Jun 27, 2011 at 6:34 PM
    BAP_29
    Ben
    North Carolina
    You put grease on the rotors? That sounds like a bad idea?
  4. Jun 27, 2011 at 6:37 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    Yea, go into NAPA and ask for a tube of brake rotor grease, they will know.
  5. Jun 27, 2011 at 6:42 PM
    BAP_29
    Ben
    North Carolina
    Aight will do.
  6. Jun 27, 2011 at 6:56 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    I'm sorry.... what?
  7. Jun 27, 2011 at 7:00 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Don't do it, never put grease on the rotor.!!!!!! NEVER EVER PUT GREASE ON THE ROTOR! You put the grease on the back of the pads(as in the part that doesn't touch the rotors). Apply brake squeal stop to the backside of the pads. it acts as a damper so that when the brakes arent pressed and instead are rattling around ever so slightly at speed...the brakes dont chatter.
    The auto parts store has brake grease in packets or a tube. You only apply it to the back of the pads. One packet is enough for 2 wheels.
  8. Jun 27, 2011 at 7:07 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    I am sorry guys, I couldnt help it. Correct... DO NOT PUT GREASE ON YOUR BRAKES AND DO NOT GRIND YOUR ROTORS. I wasnt going to let it go on for long. I am an asshole, I know. I wish I could have seen peoples faces though...
    :D
    They do have some anti-squeel grease for the back of your pads though.
  9. Jun 27, 2011 at 7:09 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    I havent done my Taco pads yet but your procedures sound correct for the most part. The rears are differant as you have drum brakes in back. Also very easy.
  10. Jun 27, 2011 at 7:11 PM
    tinker_troy
    T R O Y
    WY/SD
    I was like "he has to be drunk!"
  11. Jun 27, 2011 at 7:40 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    not funny, but it is! :anonymous: :D
  12. Jun 27, 2011 at 7:45 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    LoL OK, at least I am not the only that found that funny.
  13. Jun 27, 2011 at 7:50 PM
    BAP_29
    Ben
    North Carolina
    haha I knew it! and yet he still got me. shows how much I know I guess lol.
  14. Jun 27, 2011 at 8:18 PM
    genxer36
    Sean
    Bethlehem,GA
    Just thinking about some noob reading that & doing what you wrote. And not seeing you were kidding.
  15. Jun 27, 2011 at 8:27 PM
    seanmccarthy1
    seanmccarthy1 Member
    massachusetts
    05 sr5
    excellent video on you tube of a tacoma front brake job....
  16. Jun 27, 2011 at 8:27 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  17. Jun 27, 2011 at 8:29 PM
    BAP_29
    Ben
    North Carolina
    Yeah I've seen that 1st gen video on youtube. Are the 1st gen and 2 gen brakes pretty similar?
  18. Jun 28, 2011 at 12:36 PM
    BAP_29
    Ben
    North Carolina
    If I take off the master cylinder cap am I going to have to bleed the brakes?
  19. Jun 28, 2011 at 12:38 PM
    tinker_troy
    T R O Y
    WY/SD
    no
  20. Jun 28, 2011 at 12:51 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    You may want to wrap a rag or old towel around the open brake reservoir before you compress the caliper piston. Just in case it overflows the reservoir, you don't end up with brake fluid everywhere.
