Need DIY info on changing rear brake shoes.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Back40, Sep 27, 2013.
  1. Sep 27, 2013 at 8:59 AM
    Back40
    Back40 [OP] Well-Known Member
    SC
    2005 4x4 Dbl Cab
    Hoping someone has found some detailed DIY info (hopefully with pics or a vid) on replacing the rear shoes on a 2nd gen Tacoma. My 05 has 113k and is due some new shoes. Thanks!
  2. Sep 27, 2013 at 9:10 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    They're the same as every other Toyota drum, more or less.
  3. Sep 27, 2013 at 9:16 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Yes, I found all the detailed info you could ever need inside the Haynes manual I bought for my truck.
    Keys to proper brake job:
    1) Loosen the pads before trying to remove the drum
    2) Get new springs for everything
    3) Get the drum cut
    4) Properly adjust the pads when done otherwise you will warp your front rotors
  4. Sep 27, 2013 at 4:13 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
  5. Sep 27, 2013 at 4:33 PM
    Takohma
    Takohma Member
    Zach
    Long Island,NY
    4x4 Base
    Take off both drums and do one side at a time, use the other side as a mirror image of the side you are working on. if you get stuck or forget where a piece goes. or take a picture
  6. Sep 30, 2013 at 6:10 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  7. Sep 30, 2013 at 6:44 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    Any tricks for the parking brake cablehookup
    I had a bitch if a time with them last time
  8. Sep 30, 2013 at 7:09 AM
    XXXX
    sKiP
    05 Prius
    I had zero issues. Maybe take off the rear Leafs. Sounds like your lifted to high for the cables. They don't stretch lol
  9. Sep 30, 2013 at 7:16 AM
    BamaToy1997
    Bill
    Navarre, FL
    Nothing against any other suggestions, but this is the BEST advice in the entire thread so far.
