Need Electrical Help! Hard wiring a garmin.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davem311, Apr 15, 2014.
  1. Apr 15, 2014 at 12:17 PM
    davem311
    davem311 [OP] Active Member
    Dave
    Richmond, TX
    2010 4x4. El Taco Blanco.
    3" Pro Comp Lift. Toyo At2 285/70r18. Pro Comp Alloy Rims. TRD Intake. Fogs Anytime Mod. Oil Catch Can. SnugTop Rebel Shell. Weather TEC floor mats. Mirror Mod. Garmin Etrex Hardwire.
    Trying to hard wire my garmin etrex 20. I have an old 12 volt hook up that fits it. I cut the adapter off the end and I want to hook it up to an "add a fuse" but I am left beyond my experience when I found a white wire surrounded by other wires. can't figure out which is the positive and which is the negative.
    and once the add a fuse is hooked up which fuse slot would be best to use behind the coin tray.
    in the images i unwrapped the wires surrounding the white wire to expose both.
    thanks for any help guys!
  2. Apr 15, 2014 at 1:57 PM
    davem311
    Dave
    Richmond, TX
    sorry for posting found my own answer. can't use it because i need a converter. found one on Amazon. MODS please delete. sorry for the time.
