Need Expert Feedback On 3" Lift
Discussion in 'Suspension' started by camo junkie, Jan 16, 2014.
  1. Jan 16, 2014 at 11:32 AM
    camo junkie
    camo junkie [OP] Well-Known Member
    Greg
    Kansas
    2014 Tacoma Sport 4x4
    3" lift OME lift 887 coils, LR UCA's, 16" Stealth Custom Series Wheels and 265/75/16 Duratrac Tires
    First off, I know there has been thousands of posts about lifts but after doing multiple searches it becomes very confusing to find specific info. So, hopefully I can get some good feedback from somebody that really knows this stuff.
    I have a 2008 Access Cab 4x4 TRD Off Road that currently has Billies 5100 @ 1.75" front and 1" block at the rear. I'm wanting to go with ToyTec/Eibach coils (112-620) and utilizing my existing Billies set @ .85" for 3" front lift and a 2" AAL in the rear.
    Here's my question: Do I need to also get the Axle Shims, Carrier Bearing Drop Kit, Differential Drop Kit and should I go ahead and bite the bullet and do the light racing UCA's. Thanks
  2. Jan 16, 2014 at 11:49 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If I might make a suggestion, I would say go with:
    OME 887 coils up front - 590lb/in and about 2.75-3" Lift
    3 Leaf HD AAL set out back for about 1.75" of lift.
    UCAs are not required but at 2.5-3" of lift are certainly a good idea to have a proper Caster setting.
  3. Jan 16, 2014 at 11:53 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I agree with this but am still perplexed on the OME 887s (forefunner coil?).
    Shims, Carrier Drop, Diff Drop, are not needed unless you notice vibes/sudder issues. I personally have OME 886 coils, OME Nitrocharger all around, wheelers 3 leaf 1.5" progressive AAL + OMD Chevy leaf mod in the rear and have no issues without Shims and drops. You can sometimes get away with stock UCAs, especially if your LCA cams/bolts are seized. I did it for a little bit but in the end did get the LR UCAs.
  4. Jan 16, 2014 at 12:02 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    887s are same spring rate as the 885s, but just a bit longer. The 886s are much higher spring rate, and quite a bit longer. Really mostly for use with a bumper and winch.
  5. Jan 16, 2014 at 12:08 PM
    camo junkie
    Greg
    Kansas
    So if I went with the 886 or 887 OME's would I set the Bilsteins at .85 or 0
  6. Jan 16, 2014 at 12:09 PM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
  7. Jan 16, 2014 at 12:41 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I agree 0, but there are people that have raised them to 0.85". I wouldn't recommend it. I would recommend pairing them with OME nitro shocks.
