Need first gen lift advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by joeer77, Nov 1, 2010.
  1. Nov 1, 2010 at 3:15 PM
    joeer77
    joeer77 [OP] Active Member
    North Plains OR
    Bilstein 5100s
    Hello all. I need some lift advice to eliminate rubbing and reinstall the mud flaps. I installed a set of Bilstein 5100's this weekend on my 2004 Tacoma extended cab. I used the middle setting for 1" of lift. I am running Mickey Thompson 16X8 rims with 3.5" of backspacing. I am running 265/75/16 Goodyear Duratracs (just got this weekend too) and I still rub on sharp turns or big bumps. I had to remove the mud flaps and trim plastic to make it drivable. I was thinking about going to the 2.5" lift setting on the billies and putting a 1" block in the rear. I would like to eliminate all rubbing and put the mud flaps back on but still want the truck to look good. If anyone has any advice on a similar setup I would appreciate it. If I go to 2.5" 5100 setting, will that eliminate rubbing and allow me to install mud flaps? How much rear lift do I need to level the truck? I'm pretty frustrated since many people run 265's on stock rims without any rubbing.
  2. Nov 1, 2010 at 9:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you are still running the stock rear leafs, using lift blocks will surely hasten their demise. If your leafs are still in decent shape (no negative arch) an add a leaf kit is probably the way to go. Next step up would be a replacement leaf pack. Wheelers Offroad makes a reasonably priced set that a lot of folks are very happy with.
    Keep in mind that what ever route you go, you'll also have to replace your rear shocks. The stock ones are too short for any amount of lift.
  3. Nov 10, 2010 at 9:42 PM
    joeer77
    North Plains OR
    Bilstein 5100s
    I ended up adjusting the billies to 2.5" in the front. That eliminated the rub but the mud flaps have to remain off. I ordered 5100 rears from wheelers and a 1.5" block kit from Fat Bob's Garage in Utah. I will put it all on this weekend. Maybe I will post pics if anyone is interested.
  4. Nov 10, 2010 at 9:59 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, post your pics.
  5. Dec 22, 2010 at 2:22 PM
    joeer77
    North Plains OR
    Bilstein 5100s
    I finally got everything complete with a couple pics. I'm really happy with the setup. The lift blocks were trickier than I thought to put in. The axle likes to rotate after removing the u-bolts. I used my bottle jack to support the pinion flange and that kept it from twisting. I used the floor jack to support the axle so it was a little tricky running two jacks at once. The 5100's ride smooth. The Duratracs are really quiet considering how knobby they are. I still get a little mud flap rubbing even with the billies at 2.5" but I'm leaving the mud flaps on.
  6. Dec 27, 2010 at 8:12 PM
    Liberty
    Liberty Well-Known Member
    Frank
    1.5" lift
    looks great congrats
  7. Oct 5, 2012 at 7:27 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod, Kobalt tool box, Bulldog Keyless entry, Sportsman max-4 seat covers, modded EL Bazooka basstube, Friends of Coal sticker and license plate, Green Hooks, Green Emblems, Green LED sony radio, Green shiftknob.
    your rake is bad.... i would either get some new lift coils in the front or take the block off. the block is causing harm to your rear leafs anyways.
    EDIT: or you could just buy new eibach coils and an aal. and keep the billies, and lose the blocks! that sounds like a better plan
  8. Oct 5, 2012 at 7:39 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Quinton
    Rollin' Tides and Bangin Brides.
    01 TRD xtracab, lifted, sitting on dem dirty turty trees, actually they are clean.
    Stuff. Things as well. I like putting these on instead of those. You know, for likes.
    This
  9. Oct 5, 2012 at 7:55 AM
    Rebel Taco Man
    Tyler
    Kentucky
    Roll Tide, MAKE A BUILD THREAD! or just tell me what your runnin, on your "murdered" "lifted" truck. you got one pic and i wanna see some of yours. :mad::D:eek:
  10. Oct 5, 2012 at 10:41 AM
    brianpdx
    brianpdx Well-Known Member
    1999 SR5 TRD 4x4
    Great thing about TW - you never can tell which ancient thread will be revived from the past on any given day.
    :D
  11. Oct 5, 2012 at 8:01 PM
    Rebel Taco Man
    Tyler
    Kentucky
    hate to say this but alot of them are from me... i have a computer class at school, and im pretty technically inclined so i breeze through everything while everyone else struggles, and takes time. so i have to do something, what better than TW! :D so start with all the new threads and go back in time. and i look at builds cause im planning on lifting and what not soon, so i go to find ideas. its great. :cool:
  12. Oct 6, 2012 at 2:51 PM
    joeer77
    North Plains OR
    Bilstein 5100s
    You guys still talking about this? I got a snugtop canopy since then off Craigslist for $500. Came off a 2002 black Tacoma. Still rubs at full turn but I just put up with it. Happy with my setup overall.
  13. Oct 7, 2012 at 9:37 AM
    Roll Tide
    Quinton
    Haha. Sorry about no build thread. I started modding this spring. At the same time we found out we were going to be parents! So my modding was very direct and I honestly didn't take time to take pics. Of course, it isn't complete either. Maybe if I get some time between nursery modding I'll get the wife's camera out and create a build thread or mod list.
  14. Oct 7, 2012 at 9:45 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Which also brings us back to rake. I have always gotten comments from younger guys at work about how I need to raise my front more. Well, when I go to Lowes or put on a camper or fill the back with tools or dirt or whatever, it steers just fine down the hwy. and my front bakes aren't skipping along the pavement. His looks just fine w/ a camper.
