Need flexible mud flaps for 2012 4x4
Discussion in 'New Members' started by 32shughes, Mar 2, 2015.
  1. Mar 2, 2015 at 1:20 PM
    32shughes
    32shughes [OP] New Member
    Ventura Co.
    12 4x4
    Need to find Rubber mud flaps like on my 88 4x4. Please let me know where to get them.
  2. Mar 21, 2015 at 10:39 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'd like this too. Maybe a little shorter. I was just out pondering the ones I took off the front when I installed my 285's.
