Need ground clearance for 2004 2wd Tacoma
Discussion in 'New Members' started by kerrdan, Oct 17, 2021.
  1. Oct 17, 2021 at 1:04 PM
    kerrdan
    kerrdan [OP] New Member
    Current tires and wheels are 215/75-15. Best way ideas…pls
  2. Oct 17, 2021 at 1:12 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    buckhuntin-tacoma likes this.
  3. Oct 17, 2021 at 1:33 PM
    kerrdan
    Thanks for the links. Scanned em. Just acquired a 2004 2wd with 35,000 miles. Being new…a suggestions appreciated.
  4. Oct 17, 2021 at 2:13 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  5. Oct 17, 2021 at 2:21 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The only way to increase ground clearance is bigger tires. Of course that creates others problems that need to be solved. I'm guessing you have the 4 cyl. (It helps to include such information in order to give good advice). If so your options are limited.
  6. Oct 17, 2021 at 2:26 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Get bigger tires.
  7. Oct 17, 2021 at 2:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    Spend time reading in the 5 lug section. Because a 5 lug is what you have. Right?
    Taller tires are what makes ground clearance at the axle lines.
    On 2nd gen 5 lugs like mine, a 235 75 15 will give a real 1" of clearance with no rubbing issues, as long as you use wheels with stock specs.
    I'm not sure if this is true for your first gen, but folks over there will know.
  8. Oct 17, 2021 at 3:02 PM
    kerrdan
    Thanks all..we have a stock 2004 4cyl 2wd automatic with very low milage….vehicle has new 215/70/15 Arizonians…TW states max is 265/75/16 for 2004 with no qualifiers mentioned that I found. As a newcomer..site nav is also unfamiliar. So..with 15 wheels…265/75 or 70/15…is the plan.
    Or the underlying issues as suggested earlier be serious..can you elaborate?
  9. Oct 17, 2021 at 3:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    That would be for a 6 lug truck.
    The 15" wheels tell me you have a 5 lug.
    Am I correct?
    tacomataco2 likes this.
  10. Oct 17, 2021 at 3:14 PM
    kerrdan
    Yes Bill 5 lugs 15”…
  11. Oct 17, 2021 at 3:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    Then I'd suggest the 265 will probably not work.
    Note that our 5 lugs have a very different suspension and brakes as well, so be careful when ordering parts.
  12. Oct 17, 2021 at 3:25 PM
    kerrdan
    NOW THATS AN IMPORTANT DISTINCTION! Missed so far in my research!
    Im in rough terrain lots of rocks…unless I can get an an inch or more…I might have to trade it.
