Need help: 1st DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DCJeeper, Jan 2, 2019.
  1. Jan 2, 2019 at 10:07 AM
    DCJeeper
    DCJeeper [OP] Well-Known Member
    Hi guys:
    I'm a newbie for DIY. My 2017 Tacoma TRD OR is over 25 k miles and just finished the last free maintenance. I am going to do oil change myself and wonder if someone can recommend the tools needed for basic oil change and tire rotation. I've got a pair of ramps, a set of socket wrench. planning to buy oil filter wrench, oil drainage pan, oil filter and 7 qt full synthetic oil. Toyota recommends 10 k interval but the guy in Advance Auto Parts strongly suggests 5 k interval and I'm not sure if it's better or that's just a peace of mind. My local Toyota dealer says that they use a special synthetic oil specifically made for Toyota.
    I looked on Craigslist for floor jack and jack stands and saw some cheap ones with 2 ton capacity. Just wonder if they are enough to support the truck for tire rotation? There are also some with 3-6 tons but they are much more expensive.
  2. Jan 2, 2019 at 10:15 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Consult your owners manual for weight of oil. I think I remember it being 0w-20. But for god sakes don't take my word for it. I agree with the 5k vs 10k oil change interval. 10k is too long for my tastes. I would use a synthetic over a conventional in this case as well. The socket set will need to be metric. Otherwise you are good to go. Nothing wrong with ramps. You don't need a jack/stands for oil changing. As for tire rotation, I would NOT go cheap on the jack nor the stands. You also really need a torque wrench for the lug nuts. I know folks don't use them but they SHOULD.
  3. Jan 2, 2019 at 10:24 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    As mentioned, read your manual. You are going to get all kinds of recommendations on TW but it has been shown through 3rd party testing that what Toyota recommends is perfectly fine. That is all I will say on that subject, lol. Anyway, be safe, if you are not sure, spend more money for a better jackstand and floor jack. Don't cheap out there. Get yourself some brake cleaner as well to clean up with.
  4. Jan 2, 2019 at 10:42 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I'd recommend replacing the oil drain plug right away with a Fumoto valve..... Way cleaner...You will NOT regret it..!
    I personally like the F103N, and puta short hose on it that goes directly into the oil jug. Careful...jug will not hold it all....jug switch required.
    https://www.fumotooildrainvalve.com/f103n.html
    Also.... the oil filter housing will be VERY tight to remove....that's because it may be overtightened, but likely because of plastic/metal heating/cooling is different. Anyways...the seal for the filter is actually an "O" ring on the side of housing....not where the housing meets the truck.
    Good luck
    JNG likes this.
  5. Jan 2, 2019 at 11:15 AM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
  6. Jan 2, 2019 at 11:17 AM
    JNG
  7. Jan 2, 2019 at 11:39 AM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    10k interval for oil changes unless you fall into the sever duty category, odds are you dont.
    0-20w oil, synthetic is your only option for this weight.
    2 ton floor jack is sufficient, you're not picking up the entire truck with it.
    2-3 ton jack stands. again, not holding the full weight of the vehicle and if you did need to do all for corners then with 4 jacks you would have 4-6 ton holding (ratings are for pairs)
    harbor freight floor jacks are fine
    NEVER WORK UNDER A VEHICLE ON A FLOOR JACK.
  8. Jan 2, 2019 at 11:40 AM
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
  9. Jan 2, 2019 at 12:03 PM
    DCJeeper
    Thank you all for the replies. Very helpful! One more question: where do you buy the tools and parts like oil filter wrench, filter and oil? Dealership, auto parts store or Amazon?
  10. Jan 2, 2019 at 4:38 PM
    over60
    Muskoka, Ontario
    I used Amazon.ca for everything except the 0-20 Mobil 1.....that's Wally World for me. :canada::canada::canada:
  11. Jan 2, 2019 at 5:27 PM
    quikrain
    quikrain Well-Known Member
    2017 Red Tacoma TRD SP DCLB
    Do you have a recommendation of a good budget torque setup?
  12. Jan 2, 2019 at 10:39 PM
    JNG
    Honestly no. I'm using older Craftsman and Snap-on torque wrenches. I don't really know what's available today that is affordable yet decent quality.
  13. Jan 2, 2019 at 10:58 PM
    Larmo63
    Larmo63 Well-Known Member
    SoCal
    2019 Tacoma Access Cab TRD Sport
    What is the torque value on Tacoma alloy wheels?
  14. Jan 2, 2019 at 11:09 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    83 ft/lbs
