Need Help! 2006 Tacoma ignition is weak!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ivan915, Nov 19, 2010.
  1. Nov 19, 2010 at 9:16 AM
    Ivan915
    Ivan915 [OP] New Member
    Ivan
    Austin
    06 Tacoma
    Hello guys i need your help, a couple days ago I got in my truck, I put the keys in the ignition and turned the keys, my truck made a sound as if my battery was dead. I checked to see if I had left any lights on and nothing. I turned the keys again and this time i heard the truck wanting to start the engine didnt start till 5 seconds later. The battery is still good though. I have this problem every morning. Could it be i need a new battery or is it my starter? Any suggestions??:confused:
  2. Nov 19, 2010 at 9:29 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    I would start simple - clean the battery terminals and check that they are tight.
    You can have a bad cell in the battery causing this also.
  3. Nov 19, 2010 at 9:34 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Sounds like a battery issue to me.:cool:
  4. Nov 19, 2010 at 9:54 AM
    inouk
    inouk Well-Known Member
    test your battery with a load tester ;)
