Need help 5100 install
Discussion in 'Technical Chat' started by wksos, Feb 19, 2012.
  1. Feb 19, 2012 at 5:40 PM
    wksos
    wksos [OP] Well-Known Member
    Daniel
    Austin
    Lifted TRD
    I'm having trouble getting my struts back in and I need some advice if anyone has some. I am installing 5100/Eibachs and I'm about an inch off. I disconnected the sway bar and tried to remove the ball joint but it wouldn't break loose. Anyone done this? have any suggestions?
  2. Feb 19, 2012 at 5:44 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    Post some pics if you can. It will help people visualize your problem. What coils you use? Are you also using any spacers?
    After you disconnect you gotta hit it with a hammer and it will pop out.
  3. Feb 19, 2012 at 5:50 PM
    Geo Taco
    Geo Taco Well-Known Member
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    With my OME kit I just used the bottle jack on the uca. Place the jack upside down with the base against the wheel well and the top of the jack against the upper ball joint. Then start cranking the jack. It will move the uca, spindle, and lca. It made getting the lower bolt in very easy.
  4. Feb 19, 2012 at 5:53 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    Post a pic. You can use a jack and a piece of wood to persuade the control arm to move a little.
  5. Feb 19, 2012 at 6:04 PM
    wksos
    Daniel
    Austin
    Lifted TRD
    Ok, I'll take a pic, one minute
  6. Feb 19, 2012 at 6:05 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    You should be able to unscrew the 4 lower ball joint screws and drop the lower control arm enough to install the shock. It's best to not unscrew at least one screw on the lower ball joint so as to make it easier to put back together. If you do take them all out you can use a bottle jack under the control arm to lift it in place. Be careful you don't lift it off the frame stands.
  7. Feb 19, 2012 at 6:11 PM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Sorry I'm thinking of a 4x4 are you a 2 wheel drive?
  8. Feb 20, 2012 at 1:26 PM
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    I hope he's ok!
  9. Feb 20, 2012 at 2:29 PM
    wksos
    Daniel
    Austin
    Lifted TRD
    Sorry guys, I got it figured out.. Tight fit but I squeezed it in.
  10. Apr 14, 2012 at 12:26 PM
    rrh_2
    rrh_2 Well-Known Member
    Richard
    Devine texas
    05 tacoma 4x4 sr5 dc
    6" pro comp stage one lift ome 885's, 5100's,bhlm, billet grille, lights behind grille, k&n cai , tinted Led tails, tinted 3rd brake light, Lotek a pillar, color matched grille mirrors and door handles, trd seat covers, blacked out windows, color matched engine cover, in-dash flip out screen 2 10'' kicker subs
    Do I need to use the rubbers from my old shocks with the 5100's
