Need help adjusting ICON shocks
Discussion in 'Suspension' started by DTacoms, Nov 1, 2009.
  1. Nov 1, 2009 at 9:40 PM
    DTacoms
    DTacoms [OP] Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Hi,
    After Toyota replaced my LCAs, the front height increased by another 1 inch:confused:. I drove it for few days already but it did not settle back to the height before. I decided to adjust the coil-overs.
    The passenger side was a little bit higher (39.5") than the driver side (39"), so I adjusted the passenger first. After 6 turns, the passenger side went down to 38.5". When I checked the driver side, it went down already to 38.5" without having been adjusted.:confused: Can someone explain this?
    I really wanted to adjust the driver down since the coils are pre-loaded too much (2 3/4" thread showing) and I think the ride is harsh. The passenger side was down from 2 1/4" to 1 3/4" thread showing. What did I do wrong? Are these numbers normal to have a levelled front?
    Those who have ICONs, can you please tell me how much exposed threads in the driver and passenger sides to level the truck? Also, tell me how much lift did you get from those settings.
    Thanks.
  2. Nov 2, 2009 at 7:33 AM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Bump.
  3. Nov 2, 2009 at 9:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Every half inch of adjustment is going to yeild 1" at the tire.....If you went from 2.25" to 1.75" and lowered 1"....that sounds right.
