Need Help/Advice - Fuel Gauge Stuck In FULL Position
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truv6, Oct 1, 2024.
  1. Oct 1, 2024 at 4:23 PM
    Truv6
    Truv6 [OP] Well-Known Member
    Martin
    Castro Valley, CA
    2023 White Tacoma TRD Sport
    Hi All,
    Need some advice. I went to fill up on Sunday, and noticed that my fuel gauge needle was stuck on "full" for quite some time. Roughly about 80 miles in and it's only moved just slightly lower. I get about 270 miles a tank.
    I tried disconnecting my battery three times for about 5 minutes each time. Also opened up my gas cap to see if maybe there was some weird pressure build up or something. Still nothing.
    Truck details - 2023 TRD Sport 4x4 DCSB - About 10K miles on it. Thanks!
  2. Oct 1, 2024 at 4:24 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Unfortunately I have no answer - sounds like you'll have to roll-dice at the dealer for the fix.
    BlackTRD4Me likes this.
  3. Oct 1, 2024 at 4:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    Warranty!
    Chew and 23MGM like this.
  4. Oct 1, 2024 at 4:58 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    Is this the first you noticed this? On mine,, 2018 OR, it tends to stay on the full mark for longer than you’d think but goes down normally after it comes off full. Starts to move after about 50km.
    Taco22trdor and Jim727386 like this.
  5. Oct 1, 2024 at 4:59 PM
    Truv6
    Martin
    Castro Valley, CA
    Yeah, I was wondering if there was anything I could do in the meantime - Any fuses to check, electrical wiring, some reset button I don't know about?
  6. Oct 1, 2024 at 5:00 PM
    Truv6
    Martin
    Castro Valley, CA
    I honestly never noticed it until the morning after I filled up. What's weird is after I unplugged my battery, the fuel gauge went to full and my MPG went from 270 to 380 all of a sudden....
  7. Oct 1, 2024 at 5:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    Even my '13 Taco and '14 RAV will stay on full a disproportionate amount of miles compared to their movement afterwards. Make sure you're not seeing same.
    IE, when you hit 1/2, does a fill up hold the right amount for 1/2? Same at 1/4.
    Because if they do, the time on F doesn't much matter does it?
    And your Miles per tank is just guesswork. Calculate real MPG to know what's happening in that area.
    Chew, jmneill and MR E30 like this.
  8. Oct 1, 2024 at 5:05 PM
    Jim727386
    Jim727386 Well-Known Member
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Plain Jane - Bare bones
    My 23 DCSB usually sets at 380-385 on a full tank. I does take a while to start moving, though
  9. Oct 1, 2024 at 5:38 PM
    wiljayhi
    Jim
    Manitoba
    3G, Tuned
    When you disconnect the battery stuff “resets”. I got identical results when I replace my battery last year. DTE improved by 100km.
  10. Oct 1, 2024 at 5:53 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    You have unlimited gas! What are you complaining about?:rofl:
    Truv6[OP] and assist like this.
  11. Oct 1, 2024 at 6:48 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Maybe need some gas additive to thin things out and shake it loose. Try some hard stops or side-to-side quick turns to slosh fuel, might break it loose.
    Truv6[OP] likes this.
  12. Oct 2, 2024 at 6:46 AM
    Truv6
    Martin
    Castro Valley, CA
    Great idea, I’ll fill up at a 1/2 tank and see how much I fill up to. When I got home last night I did see the needle begin to move lower. It stays at full for a freakishly long time…
  13. Oct 2, 2024 at 6:47 AM
    Truv6
    Martin
    Castro Valley, CA
    Thanks for all the feedback, I’ll update when I get more miles on the truck!
