Need help ASAP - truck is on jacks
Discussion in 'Suspension' started by J0HN_R1, Jan 19, 2014.
  1. Jan 19, 2014 at 5:01 PM
    J0HN_R1
    J0HN_R1 [OP] Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    Installing Bilstein 5100's (set @ 2.5")...
    Cannot get the ball-joint assy to mate up with the mounting holes for the life of me.
    Already have the shock/spring seated, top-nut of the shock is hand-tight / threaded on.
    Using the "no spring-compressor method" of jacking the LCA, jack keeps lifting the truck off the stand under the frame...
    Seems to be too much pre-load on the strut assy now, for the two parts to be close enough to start the threads of the bolts.
    * doing this by myself, already tried putting my weight in the UCA to push it down.
    But I'm in a weakened-state right now (down 20lbs) after battling H1N1 flu for 2 weeks.
    Any help is appreciated, smart-ass comments & links to other threads are not... I need to finish this ASAP.
    Thank you
  2. Jan 19, 2014 at 5:16 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Use the stock bottle jack inside the wheel well above the UCA to push it down.
  3. Jan 19, 2014 at 5:21 PM
    J0HN_R1
    Calgary, Alberta
    I'll try it, but not sure the fender-liner or whatever is above the UCA will hold...?
    :notsure:
  4. Jan 19, 2014 at 5:31 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Use a piece of wood against the roof of the fender as a brace or simply disconnect the upper ball joint get the bottom put together then re attach the UCA either way is really easy.
  5. Jan 19, 2014 at 8:31 PM
    J0HN_R1
    Calgary, Alberta
    Finished... Thanks for the reply !
    * used your bottle-jack trick.
    :D
  6. Jan 20, 2014 at 4:14 AM
    Airframes Chief
    Airframes Chief Well-Known Member
    Kekoa
    Kailua-Kona, HI
    Super white TRD 4x4 DCSB
    K&N drop-in filter, AFE performance exhaust, mild sounds by Kicker/Alpine and BedRug. 7.5" lift/18x10 Moto metal black 962/33" Toto M/Ts.
    Jason that was mighty awesome of you to help out a brother in need. Kudos to you bro and John we want pics!!! I love browsing the threads and seeing outcomes such as this. Great job guys, Aloha!:D
