NEED HELP ASAP!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by je3169, Nov 8, 2014.
  1. Nov 8, 2014 at 10:18 AM
    je3169
    je3169 [OP] Well-Known Member
    Cincinnati OH
    2014 Access Cab TRD Sport
    2" Front, 2" Back, Opti-Coat Pro, Toyo Running Boards, Kenwood DNX891HD
    Guys i replaced the drivers side bearing in the front dif and am putting it back together i am at the point that i am installing the new seal and there is a spring (like a pen spring but round ) where does that go??i think it goes on the inside of the new seal can someone conferm this for mw.
    Thanks John
  2. Nov 8, 2014 at 10:20 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Usually seals have a spring on the inside lip to help seal, never taken that specific seal.
  3. Nov 8, 2014 at 10:26 AM
    je3169
    Cincinnati OH
    Thanks for reply, it shot out when the seal came out and couldn't see where it came from. There looked like a groove on the inside of the new seal that it would fit in but wasn't sure. Kinda surprised a spring doesn't come with new seal.
  4. Nov 8, 2014 at 3:24 PM
    seafur
    seafur Well-Known Member
    Pacific Northwest
    2014 DCSB MT TRD OR
    Sprinter bed tiedowns, Aux fuse box, AIO key, 3-way canopy light switch, 12V bed outlet, Dual Battery AGM G35, Viair OBA, Uni-filter mod
    I've never done seals on the Taco but seals for my old FJ60 came with springs. I'd make sure your new seals weren't supposed to have the springs, did you get a left and right set that you can compare?
  5. Nov 8, 2014 at 5:57 PM
    je3169
    Cincinnati OH
    Update thanks all for the help turns out the new seal had it in it so we jumped the gun thanks for the reply's.
  6. Nov 8, 2014 at 6:01 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Yep, the spring is normally there to add a bit of pressure to keep the lip of the seal against its sealing surface. A lot of those types of seals have the springs in them.
    Be careful when reinstaling the spring that you do not damage the seal lip.
    :cheers:
