Need help: Backspacing and Spacer question
Discussion in 'Wheels & Tires' started by JADaus, Sep 17, 2015.
  1. Sep 17, 2015 at 8:46 AM
    JADaus
    JADaus [OP] JD
    JD
    Minneapolis
    '13 Tacoma TRD Sport
    Here's what I've done: Bestop 76308-35 Black Diamond Supertop N-Fab T124LB Light Bar 2, Hella 700FF driving lights with 100w bulbs 2, Turbo SII CREE Pair 9 Inch 160w LED lights 17" Black Rock Series 997 Type 8 Matte Black Wheels 265/65-R17 Cooper Discoverer A/T3; (E class) Blue Sea Systems 5026 ST Blade Fuse Block Blue Sea Systems 285-Series Surface Mount 50A Circuit Breaker Vinyl decal by ruggedT: http://tinyurl.com/qg9bw7v Firestone W217602407 Ride-Rite Kit Daystar KU09140BK Air Bag Cradle Dog platform mod Fog lights anytime mod LED interior lights 886 Backup light mod Supreme Suspension Tacoma Lift Kit 2" Front Suspension Lift Carbon Fiber Seat Heater Kit Here's the Plan: El Cheapo Heated Mirrors mod Bilstein 24-239370 Shock Absorber (front)
    Hello
    I'm looking to get a second set of wheels/tires for my 13DCSB Sport, to run some more aggressive (winter) tires on the truck. I live in Minnesota so having a bit more traction in the winter is preferable...especially when I head north to our cabin and when i go hunting.
    I plan on being able to swap out the wheels/tires at will, want to use the exact same dimentions on tires 265/65-17...which leads me to the questions I have.
    My question is about backspacing. My stock wheels have 5.5" of backspacing and the wheels i'm looking at have 4.5" of backspacing.
    That being said, is this easily solved with spacers? I'm thinking it does, just so the backspacing isn't an issue...but i'm hoping the collective knowledge of TCWorld can help.
    Thanks!
  2. Sep 21, 2015 at 10:53 AM
    JADaus
    JADaus [OP] JD
    JD
    Minneapolis
    thought i'd bump this to see if anyone has any thoughts. total newb in this area (well, a lot of areas). :)
  3. Sep 21, 2015 at 11:27 AM
    HeavyLifter
    HeavyLifter Well-Known Member
    Jeff
    Athens, Ohio
    2013 TRD Sport
    4.5" backspacing will be fine. That's what I have on the same truck as you (2013 DCSB Sport).
    JADaus[OP] likes this.
  4. Sep 24, 2015 at 1:55 PM
    JADaus
    JADaus [OP] JD
    JD
    Minneapolis
    Thanks for the help Jeff!
