Need Help Bad 09 tacoma v6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Petey Bear, Sep 11, 2024.
  1. Oct 22, 2024 at 10:05 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is it still setting P035x codes?
    I'd get rid of that "performance" junk and put stock coils and plugs in it.
    The humming sound is normal, that's the throttle body. The hum is because the motor is PWM controlled.
  2. Oct 22, 2024 at 11:06 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you still getting the p035x codes?
  3. Nov 11, 2024 at 7:32 PM
    Petey Bear
    Petey Bear [OP] Member
    brian
    09 Tacoma Red access cab 6spd manual
    URD Long tube headers, clutch masters clutch and sleeve and bearing. Ripp coil packs. cia, cerma engine treatment(amazing beyond words). Pulstar plasma plugs
    Yes and sorry for the delay y'all.
    I forgot to mention that I put long tube headers on and a guy @ the walmart acc where I work said he forgot to tune a hemi after long tube headers and he had misfires. The long tube headers were dumping to.much fuel. I had them on for 2 weeks then this happened.
    So like I said I put the new coil packs on and plugs, it wants to start but it's not making connection, but my coworker, and a former trucking coworker, BOTH said... IT NEEDS A TUNE, I HAVE TO TUNE IT.
    What's a good tuner for our trucks? I will be doing other upgrades later on.
    Thanks
    Brian
  4. Nov 11, 2024 at 7:34 PM
    Petey Bear
    brian
    The humming sound was not present before all those happened.
  5. Nov 11, 2024 at 7:34 PM
    TnShooter
    Deogee
    STOCK
    A tune wont fix P035x codes.
    You have have a failure to confirm ignition.
    You need to check the IGF circuit.
    Canadian Caber, TireFire and Dm93 like this.
  6. Nov 12, 2024 at 7:27 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    That’s nonsense. You don’t need a tune for long tube headers. And if anything they would cause a leaner fuel mix, not rich. A good tune would be beneficial but definitely not what’s causing your trouble
