need help bad!!! again....
Discussion in 'Suspension' started by taco_man, Nov 14, 2009.
  1. Nov 14, 2009 at 7:00 AM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    what should i be torqueing my front shocks down to on the lower control arm. then what about the sway bar bolt that goes into the spindle. o and i forgot this one... the three up on top on the shock assembly... my truck is currently in pieces so i need help quick.
  2. Nov 14, 2009 at 7:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    the 3 Top nuts are 47 lbs-ft
    Lower shock mount bolt 61 lbs-ft
    Sway bar nut (to spindle) is 52 lbs-ft.
  3. Nov 14, 2009 at 7:41 AM
    taco_man
    Austin
    Houston
    09 texas edition
    forgot one more. i need the uca bolt that connects to the spindal.
  4. Nov 14, 2009 at 7:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    81 ft-lbs
  5. Nov 14, 2009 at 7:49 AM
    taco_man
    Austin
    Houston
    09 texas edition
    even with the tc uca?
  6. Nov 14, 2009 at 7:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    TC UCA gets 90# on the spindle bolt
  7. Nov 14, 2009 at 8:27 AM
    taco_man
    Austin
    Houston
    09 texas edition
    is # ft/lbs? and on the 2 bottom bolts that connect the brake disc rotor thing i torqued those to 80. is that fine?
  8. Nov 14, 2009 at 8:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah # = Ft-lbs.
    I dont know what you mean by " brake disc rotor thing".....
  9. Nov 14, 2009 at 8:37 AM
    taco_man
    Austin
    Houston
    09 texas edition
    oh my bad. its actually the bottom of the spindle connecting to the lca. there are 2 bolts under there.
  10. Nov 14, 2009 at 8:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They get tightened to 118#'s
  11. Nov 14, 2009 at 9:10 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
