Need help - bad cats?
Discussion in '1st Gen. Tacomas (1995-2004)' started by .Trdtaco315., Sep 1, 2010.
  1. Sep 1, 2010 at 2:01 PM
    .Trdtaco315.
    .Trdtaco315. [OP] Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    i keep hearing a screech sound coming from the exhaust, or a rattle in the muffler or cat.
    i also down shifted and heard a screeching sound, i am clueless. maybe some taco expert can help.
  2. Sep 1, 2010 at 2:15 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    screech could be a messed up baffle but other than that i dont really know. id like to say something intelligent about the tranny but then i would be telling you a lie hopefully someone knowledgable can chime in
  3. Sep 1, 2010 at 2:36 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Could you make me a video or else explain to me a little better about it? Is it coming from the front or the back? Do you feel/hear it when you shift, and only when you shift? Does it seem to affect how the truck runs? There are a lot of things that can go screech...
  4. Sep 1, 2010 at 2:47 PM
    .Trdtaco315.
    Will
    Santa ana
    i dont feel it but i hear it it sounds like its coming from the back. no it does really effect the truck.
    i was dropping my gf off at school and i have go down a steep hill ass hill, but as i was goin down someone pulled out in front of me so i went down to 1st and heard a nasty noise. and i was going fast at all
  5. Sep 1, 2010 at 6:44 PM
    memario1214
    Colton
    Missoula, MT
    And it is a screech? Not a crunching or grinding sound right? Things I can think of right off the top of my head is that maybe you have a transmission issue or else your exhaust may be sliding around on the hangers or something. Check all of the hang points of the exhaust and also check to make sure to make sure that your exhaust isn't touching metal to metal anywhere...
  6. Sep 1, 2010 at 7:35 PM
    malander
    max
    01 limited trd 4x4
    if its coming from the back i would check the diff. idk if that would cause the weird shifting behavior though
  7. Sep 1, 2010 at 10:55 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Grease your drive shaft lately? I had a screeching sound from the back, thought it was the brakes but It turns out that my drive shaft was dry.
  8. Sep 2, 2010 at 11:09 PM
    .Trdtaco315.
    Will
    Santa ana
    sooo i looked under my truck and my exhaust mount is broke, so maybe thats it. im gunna get it weld back up and see if it helps.
    i kinda have a feeling its the tranny tho =/ in the morning it takes a while to shift through gears.
  9. Sep 2, 2010 at 11:11 PM
    .Trdtaco315.
    Will
    Santa ana
    yeah i had that issue with a u-joint, but i need to greasy my drive shaft.
